  • geerbangr
  • geerbangr's Avatar
29 Sep 2013 05:24
#608181
Anyone have any knowledge on this macheen :woohoo:
www.kzrider.com/media/kunena/attachments...Z12013byZealot20.jpg
It's like Viagra on two wheels :silly: :woohoo: :silly:
1978 KZ 1000
I go by Jason
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
29 Sep 2013 05:51
#608182
bluezbike wrote: Zukdave, how about relocating the cooler, maybe in front of the forks just above the fender, or just under the headlight? That way maybe you can lower the forks in the trees. Just an idea that may save some time and moolah.
Agreed, but strap the forks down, don't slide them through the trees. Raking the frame effectively moves the engine back in the chassis. This will make wheelies worse. It's what we did back in the 80s when tyres were crap and we didn't know any better. Look at the quick streetbikes now. They have all the weight up front and a long arm to take advantage of good tyres.
Sorry for the threadjack... ;)
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
  • old-school
  • old-school's Avatar
29 Sep 2013 09:44
#608188
Do you have any pictures you can share of strapping down the stock KZ front end?
Thanks
(2) 76 KZ900s, 81 CSR1000 and 81 GPZ1100
  • zukdave
  • zukdave's Avatar
29 Sep 2013 10:16 - 29 Sep 2013 10:24
#608198
I forgot this is in my Drag strip thread
there's pic's on what I want.
www.kzrider.com/forum/25-racing/509014-d...strip-trip?start=160
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Last edit: 29 Sep 2013 10:24 by zukdave.
The following user(s) said Thank You: old-school
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
29 Sep 2013 15:31
#608241
Strapping the front is much better than sliding the forks through the yokes as it also stiffens the fork and means the front wheel won't move any further than it would as standard, so no clearance issues will come from it.
You can also vary the strap to suit different tracks and the grip available - strap down hard for a grippy track and less so for marginal tracks.
Here's my 750 strapped down to about 1.5" of movement (4" standard).
I ran 1.56 sixty foots at 60" (+2" from standard) wheelbase with this setup.
If you rake the front you'll most likely find that it hits the bars harder but every pound of weight ON the bars is a pound OFF the rear tyre which is where you want it to be. Keep the weight towards the front of the bike and adjust the wheelbase is the modern way.
Here's my 760cc bike with 4" welded in the arm from another bike - a KLR650! You can see the welds in this pic and the support plate underneath which doubled as a wheelie bar mount.
760cc - 8.69@162mph
  • zukdave
  • zukdave's Avatar
29 Sep 2013 20:09
#608272
With the GPz arm I'm 2 1/2" over stock.
I have a strap but it still will hit the cooler.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • geerbangr
30 Sep 2013 02:02
#608301
Wth is the guy doing behind that bike with the hockey stick and a brick ? :S
1978 KZ 1000
I go by Jason
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
30 Sep 2013 03:04
#608305
zukdave wrote: With the GPz arm I'm 2 1/2" over stock.
So move the cooler :)
760cc - 8.69@162mph
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
30 Sep 2013 03:07
#608306
geerbangr wrote: Wth is the guy doing behind that bike with the hockey stick and a brick ? :S
I knew someone would ask that... :lol:
This was at a sprint event back in the 90s. Back then once you had staged you could, if you wanted to cheat the clocks, roll back a little before launching without triggering a red light in order to get a run up at the lights. So they had a guy with a wooden chock to stop you. They still do this at certain historic events like Brighton Speed Trials.
760cc - 8.69@162mph
  • geerbangr
01 Oct 2013 00:43
#608426
Alright Lorcan that makes sense. I looked at that pic,scratched my head and went :blink: :ohmy:
1978 KZ 1000
I go by Jason
  • DoctoRot
  • DoctoRot's Avatar
  • Puffin
  • Puffin's Avatar
08 Oct 2013 07:03
#609227
DoctoRot wrote:
Very cool looking Racer Doc, do you have anymore photos/info on it. Chassis looks very much like a Zuk B)
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
