- Thank you received: 225
Kreem Blue Shield... So far So Good!
- Old Man Rock
17 Feb 2009 04:11 - 17 Feb 2009 04:12 #265614
by Old Man Rock
Yup.... My Keihin CR Specials came with the pilots out 1 full turn.
In review of the plugs (all 4 cylinders the same) I have now backed the pilots out an additional 1/2 turn.... Keeping an eye on the plugs....
I'd rather be Rich then Lean until I get everything all dialed in for optimizations. SO being very careful with this for now....
Have Morgan Carb-Tune unit on the way from England as we speak.... Should be here by end of the week.... Once I get the carbs synched to perfection then I will work on the pilots for tighter adjustments (idle response, rich/lean.) Then onto Jetting!
I started a posting on the Keihin synch/jet adjusting and once all is completed, I will put together a little tutorial on it...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Kreem Blue Shield... So far So Good!
OMR that plug looks rich to me.
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 17 Feb 2009 04:12 by Old Man Rock.
- 79MKII
- Love Them Kaws!
- Thank you received: 43
17 Feb 2009 04:42 #265617
by 79MKII
The Kaw List:
Replied by 79MKII on topic Kreem Blue Shield... So far So Good!
kpier998 wrote:
All of the smog items are long gone. Brand new carbs weren't very close to where they should have been and were WAY out of synch. I was just getting things closer to being dialed in and the snow started to fly.
OMR - definitely keep us updated - and include lots of pictures! My plugs look as bad or worse than yours. I don't think it would have even been running except I have an MSD ignition that burns just about anything! :laugh: There's no reason my poor plugs shouldn't have been fouled. How hard would it be to go with EFI?:laugh:
79MKII wrote:
I think mine turned blue from being too rich instead of too lean. Does that make sense? The carbs were really rich...
Does it have air injection for the exhaust? If so, then when you run rich you should get more heat in the exhaust once the air is introduced because it would have more raw fuel to burn.
The Kaw List:
