Polishing Parts (again)
09 Feb 2009 16:26 - 09 Feb 2009 16:27 #263360 by roy-b-boy-b
Polishing Parts (again) was created by roy-b-boy-b
I have been cleaning up parts and was thinking of all the casting flaws in the Alunimun.
I was doing Yamaha today and there were small flaws. I polished some Suzuki parts last year and they were the pitts.(literly)
I hate casting flaws. They turn a fairly easy job into a bummer chore.
Just venting!:woohoo:
Last edit: 09 Feb 2009 16:27 by roy-b-boy-b.
09 Feb 2009 17:58 #263380 by 79MKII
Replied by 79MKII on topic Polishing Parts (again)
I have some kawasaki parts and even an Akront part that I'd be willing to let you polish for your research... :whistle:
The Kaw List:
09 Feb 2009 18:44 #263396 by roy-b-boy-b
Replied by roy-b-boy-b on topic Polishing Parts (again)
What is that :whistle: Whistle in the dark?:P
10 Feb 2009 05:10 #263491 by wiredgeorge
Replied by wiredgeorge on topic Polishing Parts (again)
Akront is a town in the middle of Ohio. Don't you KY boys know nuthin?
10 Feb 2009 05:54 #263497 by roy-b-boy-b
Hey George! I know nuthin!:blink:
10 Feb 2009 06:16 #263501 by 79MKII
Yea, LeBron James if from Akront...
The Kaw List:
  • Limey
  • 3 Years in the U.K. - Brought the KZ with me!
10 Feb 2009 07:49 #263516 by Limey
Replied by Limey on topic Polishing Parts (again)
Speaking of polishing parts - does anybody know an easy way to remove the clear laquer that the Japanese manufaturers put on polished aluminum? You know, the stuff that eventually starts to peel off, turns yellow and looks disgusting.
The only method I have found is to actually polish it off - which takes ages. I have tried all the usual paint removers, but nothing seems to work.
Eric
Newmarket, England (for 3 years)
Pentwater, Michighan (Home)
1978 KZ650
2000 ZG1000
2006 Suzuki Burgman 650
10 Feb 2009 08:58 #263523 by roy-b-boy-b
I use the "aircraft" paint remover and it doesn't work all the time.
I have been using the blue clay. I think it is for stainless and it seems to get heatin the alunimun faster.
Heat from the friction of the polishing process seems the biggest factor in removal of the coating.
I get the alum so hot i burn my hands if i happen to touch a area where my gloves have holes.:blush:
10 Feb 2009 12:37 #263569 by wiredgeorge
To remove the peeling lacquer, bead blast... its a lot easier than sanding and that stuff doesn't like to be removed with chemicals.
11 Feb 2009 14:35 #263869 by CRO DOG
Replied by CRO DOG on topic Polishing Parts (again)
Well I have some forks on my 80 that I got some really coarse steel wool and knocked em out without having to deal with corrosive stuff and fumes. Then I used finer wool and be darned if it didn't look really shiny before I hit it with fine sandpaper and buffed it. It is tedious work but that is what makes your bike stand out from others.
1975 z1 with many custom parts. Built by EPE performance cycles.
Chicago, Il
09 Mar 2009 18:59 #270745 by roy-b-boy-b
How bored do you have to polish a oil pan?
Very!!!!!!!!:laugh:
09 Mar 2009 18:59 - 09 Mar 2009 19:13 #270746 by roy-b-boy-b
OOOPS:blush:
Last edit: 09 Mar 2009 19:13 by roy-b-boy-b.
