Crap tool alert, Motion Pro Syncpro sync tool
- Jeff.Saunders
I know it's been 2 years since I posted this, but just an update. After my first piece of crap set of the motion pro syncpro, motion pro agreed to send me a new set, so here's an update. Today I go to use them for the first time. As a test I suck on one tube and liquid actually rose, I suck on the next two tubes and liquid rises also, however it does not go back in the tool, so now all three tubes have a mix of liquid/air gaps at the botton 2" or so of each tube. I suck on tube #4 and get nothing. I see now all the liquid has evaporated over the last two years in tube #4 and the other 3 are now empty except for the remnants that remain in the three tubes. Don't buy this piece of utter crap. I've see crap tools, but this is the biggest crap I've ever encountered for close to $100 I didn't even get to sync one set of carbs despite having 2 different sets of this "tool". Motion Pro is all chinese junk, the entire line of product.
Ron, how come you don't have a factory sync tool then? I know it would have to painted in original colors - as heaven forbid if someone repainted it! :lol:
Do I like the MP carb sync tool? Personally I don't. I'm with you on the issue of the liquid evaporating - I don't feel it should - but some of that is also how you store it. Most customers have not had problems with it. However, in terms of complaints, I know MP has received a number on the tool. They admit there are many bikes where the vacuum exceeds the capability of the tool. MP quotes a vacuum max for the tool of 40cm/Hg max. Unfortunately most shop manuals don't tell what vacuum is generated on each bike. I do know mechanical slide carbs like the VM24, VM26, VM28 and VM29's can generate more than 40cm/Hg depending on the health of the engine and the cams/cam timing setup.
You are never ever happy with anything that doesn't come with Kawasaki stamped on it - so why do you even buy any aftermarket parts - is it just so you can badmouth all the different suppliers? A few years ago you badmouthed the MP cables - only to retract that comment when you realized you'd been using MP clutch cable on your bike without issue for many years? Remember that?
A few Motion Pro tools are made in China. But most are not. If you look through the MP line, many of the tools they sell are made in the USA - others are made in Taiwan. As I look across the complete MP line, percentage-wise very few of their products are made in China. So don't make blanket statements like all MP stuff if Chinese - it's not...
www.z1enterprises.com
Z1 Ent on Facebook,
- RonKZ650
- Thank you received: 240
I would have ordered from Z1 if you had these. I saw the gauges and was a little worried over quality of the $59 gauges and didn't think $200+ on the better quality was something I wanted, and no use buying another Motion Pro as it *doesn't work* so what good is it? Very disappointing they would even stoop so low to sell this tool, as the old mercury stix worked great, but that's our government keeping us safe. Also since this "precision tool" cannot be stored in freezing temps it can't be kept in the garage with the regular tools so I kept it indoors where temps ranged from around 55 to 85 degrees. That was not good enough to ensure this *tool* and I use the term loosely would be fit to be used one time. Oh well It's happily in the trash now and I await Morgan to arrive with high hopes.
- stonemaster
- Visitor
- dkmk
- Thank you received: 18
Same here, but over time I've found that the hoses have started to break down. Just a simple matter of replacing them, otherwise they work great.I bought the lower set seen in OMR's reply. I got them from Z1... They work great.
Northern Ontario
Zapp: "Kif, I'm feeling the Captain's Itch."
Kif: "I'll get the powder, sir."
- RonKZ650
out of NJ and it got here today. Took 6 days including the weekend, so great service there. No need to wait for shipping from England. To sum up the tool, it still uses restrictors which had me a little worried as these were crap on the motion pro tool, but these restrictors are at least sensible, clear plastic hose with a restriction similar in size to a pilot jet. The motion pro restriction was like a human hair and will not and cannot possibly work. I put the restrictors in and read about the tool which I wasn't too familier with, but basically it is 4 glass tubes with stainless steel rods that rise with vacuum. Range of reading is 8cmhg to 42cmhg and if you need lower range the tool can be hung upside down and you read from 0cmhg to 8cmhg. There is no mercury as used in the past and no colored water that the motion pro uses that evaporates and freezes. The motion pro if you're lucky enough that it does work, needs to be manually calibrated, this tool doesn't need anything. I sucked on all 4 hoses at once and I got 4 stainless steel rods rising the same height! Yay, it's going to work. I'm happy.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Update, I got the Morgan Carbtune from Beemerboneyard.com
Right on man, and believe me, they work very well.
Occasionally a rod will stick in place at lower rpm/vacuum, dont worry - its just the placement of the unit, and they suggest to just rev the bike quickly and it works great. Rev - adjust - rev - adjust and your done.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
