- Thank you received: 14
Drilled to perfection,,,
- Bluemeanie
- The Milkman
- Thank you received: 194
- Thank you received: 2098
- Evilfrog
Surface area has nothing to do with stopping power. Coefficient_of_friction and force applied is what determines stopping power. A rotor the size of a penny and a break pad the size of needle would have the same stopping force if the same pressure is applied.
However; that set up would melt and meld together as soon as the break is pressed. Larger pads and rotors are for heat distribution. So this set up should be fine as far as stopping the bike...
Unless the rotor breaks. Then you're screwed.
Disclaimer: The above is a product of a physics 101 at a Community College. So please feel free to correct me if I am wrong.
1981? CSR 1000 -- I'll figure it out soon enough.
- harm
- Tom
- Thank you received: 13
Some of you may remember the sprocket i made, it has held up great with no real signs of wear after 3k miles!
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- rstnick
- Thank you received: 377
May not have too much affect, but I believe the stock kawi drilled rotors were ballanced.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- steell
I believe you forgot to take into account the increased leverage available due to the larger distance between the caliper and the axle centerline with a larger rotor. That has a very large effect.
To illustrate:
There are two bikes here, GPz750 Turbo and KZ750 twin, both weigh about the same, have same diameter master cylinder, and same calipers, but the Turbo has 10" rotors while the 750 twin has 12" rotors.
And the 750 twin will easily stop faster in a shorter distance than the Turbo in side by side comparisons.
- Old Man Rock
- Thank you received: 225
I'm sure the bike stops well enough for not all of us are driving at 100mph plus on a regular basis.
The guy/gal probably drives his bike as I plan to do (when project completed) where keeping to the speed limits (+/- 10 mph), leaving enough distance between me and the car in front of me and keeping an eye on my surroundings due to all the BS people on their cell phones not paying attention...
Sweet Meanie!
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- PLUMMEN
- Thank you received: 104
that sprocket is pretty cool looking !That won't break and it looks cool!
