- Thank you received: 103
Roy Gets Another Bike
- roy-b-boy-b
I don't like the vance and hines pipe. I am going to have to customize it also. I put a Kerker tip and baffle and that sounded better. Roy
- PLUMMEN
- Thank you received: 104
looks like a 78 a2 to me,that would explain the petcock also;)I think the engine is close to or stock. I just pulled the carbs and they are 28 pumpers.The jets are 17.5 and 117.5. K+N pods that look like they need replacing.
I need to check the timing and the coil voltage.
I thought the gas tank was a big KZ900 tank but it has the petcock that is held in with two screws and has a vacum line to activate the fuel flow.
I need to dig out a regulator and install signals on the bike. Also there is no licence plate bracket.
I'll take $2000.00
- roy-b-boy-b
- PLUMMEN
- roy-b-boy-b
- roy-b-boy-b
I used assembly lube on the cam and bearings and i'm glad i did. Was a bit noisy before the oil got to the top. Maybe i need to replace th oil pump.
Being a old drag bike i think i need to replace the clutch basket also. There is a whole lot of shaking going on when the cluth engages.
I have three sets of carbs to go through to decide which ones i want to use. Two sets of 28's and on set of 26's. I'll probably go with the 26's if they check out alright.
It was a nice day for a ride. I just had on a levi jacket and long sleeve "T" shirt. I hope the weather is nice again tomorrow. Come on spring. Roy
- roy-b-boy-b
The jets were three sizes too small on the idle and eight sizes on the mains. I ended up with 20/120.
The licence plate was zip tied to the shock so i made a bracket that would bolt to the chain guard mount. I will later move it back under the duck tail.
I mounted the D+D carbon canister so i can ride tomorrow.
The bike goes like a streak but the clutch is got to be changed out before summer. I found another clutch basket but i will have to dig out my other clutch parts.
It is suppose to be in the 50's tomorrow and i want to ride.
Roy
- StreetfighterKz
- Thank you received: 117
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
- roy-b-boy-b
I am going to put a 1075 engine on the bike. I have one that dowsn't need anything.That way i can wrench at leasure.:laugh: Roy
- StreetfighterKz
Later, Doug
1989 Vmax
- roy-b-boy-b
- roy-b-boy-b
This is the engine i installed two days before Ohio and haven't rode it.
I got out my dial caliper and the battery was dead so i get to start in the morning again.
The lift is super nice. I got the one on display and didn't have to assemble. Roy
