- Thank you received: 28
Weight, riding 2-up.
- TeK9iNe
- What did you do!?!
04 Oct 2008 21:16 #240195
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Weight, riding 2-up. was created by TeK9iNe
How much weight can I actually put on this bike?
My girlfriend and I weigh in at 420lbs, mostly my contribution
Will this be ok for the bike? What other things are there to consider?
Iv'e heard of guys loading these bikes pretty heavy, but...
Cheers!
Cheers!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- MFolks
- Thank you received: 540
04 Oct 2008 21:54 #240198
by MFolks
Replied by MFolks on topic Weight, riding 2-up.
Stronger rear springs,new rear shocks, tires inflated to maximum when cold,heavier weight oil in front forks. Just a few things to consider........
- RonKZ650
- Thank you received: 240
05 Oct 2008 08:56 #240239
by RonKZ650
Replied by RonKZ650 on topic Weight, riding 2-up.
You can look at the sticker on the steering stem for the GVWR and subtract the weight of the motorcycle to get an idea if you are overloading. A KZ650 has a GVWR of 803lbs. My wife and I weigh about 360lbs combined. Subtract 360 from 803 and get 443lbs. So does a KZ650 weigh more than 443lbs I wonder I think we are all overloading when carrying a passenger.
- H2RICK
- Is this a fun bike, or what!!!
- Thank you received: 1
06 Oct 2008 19:48 #240482
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic Weight, riding 2-up.
According to the FSM, 650's through the 1980 model year weigh anywhere from 211 kg to 219 kg DRY !!! That's 465 lb - 482 lb for you metrically challenged folks.
Well, I guessed my 650C2 was no featherweight.....but 219 kg DRY ??? :S
And those are the factory numbers which we all know are USUALLY quite...um...er.."optimistic"....:laugh: :laugh:
