z1 swingarm bearings
- pcron
- Mcdroid
- Gone Kwackers
- Thank you received: 316
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- pcron
- Thank you received: 2098
Hi all,just signed up to forum and i am looking for some help.I have a 1975 z1b.It has mag wheels and disc brakes front and back.I got a swingarm bearing kit to fit a z1/kz900 but it is too small.The needle roller bearings i got have an outside diameter of 28mm but my swingarm inside diameter is 33mm.The fact it is a disc brake swingarm i know it must be from a different model.I have seen a pic of a kz900LTD and the wheels look the same but i dont know if it had a rear disc. Can anyone help?
Hello, pcron, and WELCOME to KZR! We're glad you're here!
Thinking not a KZ900-B1(LTD) rear disc equipped swingarm with exposed master cylinder. Later year rear disc model KZ1000 has rear master cylinder hidden underneath the right side cover.
Sorry, don't know KZ models using 33mm swingarms, or if other 33mm internals (such as sleeve, etc.) are different or would have required more fitment adaptations to 1975 Z1. But other members certainly will know. Do recall that bushings were sometimes "updated" by owners who replaced them with needle bearings.
Good Luck!
- pcron
- pcron
- PLUMMEN
- Thank you received: 104
- RonKZ650
- Thank you received: 240
- MFolks
- Thank you received: 540
looks like 1000 ltd arm ;)did the swingarm have single or double needle bearing cages on each side?single would put it at 77 i believe double would be 78 or newer
Good call -- FSM covering '77-'79 KZ1000's has diagram showing two needle bearings on each side, with notation (One on each side of '77 model).
Z1E lists the oem bushing
bushing
and also lists a needle bearing kit (presumably an upgrade item)-- note four bearings -- needle bearing
Kawasaki.com's diagram for each year KZ1000 (77/78/79) shows one needle bearing on each side, but does indeed call for four in the parts listing for the '77 as well as 78/79. :huh: And the same swingarm sleeve #33034-025 for 77/78/79. :S
Good Luck!
- modprod
- PLUMMEN
learned that little trick back in late 70s.had a couple late 900 arms with bushings and a 77 kz1000 arm with single bearings sent to machinist for line bore to have double bearings installed,then went to have 78 a2 arm done and realized it already had double bearings in it.cant remember what i had for lunch today,but i remembered that from 30 years ago when i started messing with these bikes.scary!:blink: :woohoo:PLUMMEN wrote:
bushing
Good Luck!
