1979 KZ 1000ST Back from the shop
- KOOL RYDER
- KZ 650B2 / KZ 1000E
27 Jul 2008 22:34 #228626
by KOOL RYDER
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
1979 KZ 1000ST Back from the shop was created by KOOL RYDER
So I had to get an out of province inspection on my 1000ST, it needed some minor work and now it runs grreat.
A few questions, anyone else have one of these monsters?
Any tricks running them, known problems, do they run an electric ignition or points and other interesting info?
I was wondering if this bike has any know handeling characteristics? It is heavy and solid on the highway.
How does the horse power, top speed, torque compare?
1978 KZ650B
1979 KZ1000ST
- RonKZ650
- Thank you received: 240
29 Jul 2008 17:15 #228996
by RonKZ650
Replied by RonKZ650 on topic 1979 KZ 1000ST Back from the shop
It's been discussed quite a bit here before. The motorcycle is the heaviest duty Kawasaki ever. Look at the forks and compare to other KZs you'll note the legs are much bigger diameter, the frame is heavier. Everything on it is first class in both style and function. Think about replacing the cheapo ball bearings in the steering stem with tapered? Well, they already are on the ST, but not the chain drive models. Being a shaft it had slight power disadvantage to the chain drive, plus being heavier, it won't outperform a chain drive model, but it's no slouch either. I'm too lazy to look through magazines right now, but I think the difference was only like 3 or 4mph top speed and maybe 1/4 second in the quarter mile between the 79ST and 79MKII in performance. The Cycle World test said the ST was smoother running with less vibration, but they still liked the MKII better. The seat and tank on a ST is wider than the MKII and bothered some riders. Both are tanks and solid as a rock driving down the interstate and to me the ST is better, but I've only ridden my ST like 100 miles in the 8 yrs I've had it vs 80,000 on the MKII so over time it's hard to say. Both use electronic ignition.
- 6leafclover
25 Sep 2008 22:10 #238704
by 6leafclover
1979 KZ1000-E1/ST
Madison, IN
Replied by 6leafclover on topic 1979 KZ 1000ST Back from the shop
I have a 79 st also its the first street bike ive ever had, i love it, its easy to handle and was very easy to get used to and runs great, all around a good bike in my opinion
1979 KZ1000-E1/ST
Madison, IN
