- Thank you received: 1
Bordering on dumb question
- H2RICK
- Is this a fun bike, or what!!!
Your ignorance of bikes is a fixable condition because you are willing to ask and learn. Great !!! You're already ahead of the learning curve.
If the collective knowledge of this board can't solve your KZ problems then you will have stumped the biggest KZ brain trust on the planet....and I don't think that will ever happen.:laugh:
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
- JR
- Thank you received: 445
- stallau
I have both the Clymer and Haynes manuals. I bought the haynes because the clymer didn't have the oil capacity listed in it and I didn't feel like guessing. So I have two questions.
1) How do you get comfortable knowing that your work won't come unbolted while cruising down the road (usually without you knowing it happened)
2) Would getting the manual from Kawasaki add info or graphics that would be worth the expense?
- PLUMMEN
- Thank you received: 104
- KZ250LTD
- Thank you received: 16
- Becker
- The Doctor Will Rise Again
Some things I have learned over the years.
1. Always put bolts back into there holes as your disassembling.
2. Keep your tools, parts and shop clean. Everything is just so much easier this way.
3. Try and find a picture of what to expect inside of whatever your working on first.
4. Trust your instincts. If it doesn't feel right there is a reason. If that bolt is hard to turn in make sure its not cross threaded, if it seems like its not fitting maybe its because there is something in the way.
5. Ask questions. Lots and lots of questions. Ask questions until people get tired of answering them and tell you to stop.
6. Allow for twice as much time as you think it will take. This way you can take your time and still feel good about getting done ahead of schedule.
7. If its broken or going be broken shortly do it right and fix it.
8. If it ain't broke don't screw with it. (My personal must broken rule)
9. Finally, double check everything.
Hopefully that helps get you started.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
- N0NB
- Blue handles better
Thanks for the suggestions. I especially like the digital camera idea, the pictures in my mind never are quite as clear when the days go by.
You're quite welcome. I wish I could say it was my original idea, but it's not.
Get thee a pair of torque wrenches. One will do foot-pounds for the big stuff like axle bolts and the other, smaller, will do inch-pounds for the more delicate fasteners. The latter is important because you want the fastener tight enough, but you don't want to over tighten a steel bolt into aluminum threads. Doing so will result in becoming familiar with another tool--the heli-coil kit. :S
Yes, yes. While three manuals may seem confusing, you'll have three ways of looking at a given procedure, each from a different point of view. You'll also be secure in the knowledge that if there is a conflict of info, the factory manual is the final word.
Knowledge is power.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel )
