- Thank you received: 3
sea foam
- hydrolazer
02 Apr 2008 17:21 #203825
by hydrolazer
\'79 kaw 1000 ltd
sea foam was created by hydrolazer
just got a can of sea foam for my bike. how do you guys use it for the best results?....t i a
\'79 kaw 1000 ltd
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
02 Apr 2008 17:31 #203829
by The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Replied by The Gringo on topic sea foam
In a tank of fresh gas I add two shot glasses of seafoam. But then and again I'm a bartender.:laugh:
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- ran429
- Master of FREE rides!
02 Apr 2008 18:56 #203851
by ran429
Replied by ran429 on topic sea foam
a tablespoon into each spark plug hole, then light it up.
Suck some up a vacuum line into each carb, hold breath it will get smoky. Cleans valves fast.
like said above, two shots in a tank of fuel every third tank.
pour a shot or so in oil, run for awhile. Cleans/breaks down engine buildup.
pour into transmission, cleans and softens seals.
- N0NB
- Blue handles better
02 Apr 2008 18:56 #203852
by N0NB
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel )
Replied by N0NB on topic sea foam
I put in a splash or two by the highly scientific method of gestimation!
Nate
- roy-b-boy-b
- Thank you received: 103
03 Apr 2008 04:42 #203919
by roy-b-boy-b
Replied by roy-b-boy-b on topic sea foam
I was cleaning a set of carbs off a GL1000 and the bowls were thick with varnish and crud. I ran out of carb cleaner so i just poured seafoam in each bowl. I let them set a while and the Seafoam broke the varnish/crud loose. I'll start using this method from now on. Roy
- Jeff.Saunders
03 Apr 2008 05:31 #203920
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic sea foam
Seafoam does work well. I use Seafoam as a maintenance dose on some of my things that don't get run frequently - powerwasher, snowblower, lawnmower etc.
I like Yamaha's Ringfree too. I think that works better for cases where the rings are badly gummed into the pistons.
Z1 Ent on Facebook,
- Locozuna
03 Apr 2008 05:42 #203922
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic sea foam
My name is Logan and I am a Seafoam user......:blink:
I copped my first Seafoam from the Allied Auto Store back in 92'. Back then I had a wife, 2 kids, a dog, a lawn mower, a chainsaw, a generator, a bass boat, a F150 and a Oldsamabuick. Today I have all new stuff. I owe everything to Seafoam!!:woohoo:
It really is good stuff! Really!
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- davenkids2001
- Thank you received: 2
03 Apr 2008 05:49 #203924
by davenkids2001
Dave and Janet
Great Lake State
1979 650SR
Replied by davenkids2001 on topic sea foam
SEAFOAM has a lot of fans on this site. I used it for the first time last year when my carbs started pissing gas. Worked great!
I mixed it according to the label instructions into 1 gallon of gas and it worked very quickly (carb stopped pissing gas out the overflow) and have added it every few tankfulls ever since.
Dave and Janet
Great Lake State
1979 650SR
- ltdrider
- Thank you received: 17
03 Apr 2008 06:44 #203934
by ltdrider
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Replied by ltdrider on topic sea foam
I let my Voyager sit for about 4 months during the winter, and the Primary Jets got gummed up. Bike would run, but wouldn't idle. I put about 6 oz of Seafoam in with 2 gal of fresh gas, and started doing laps around the block. By the time I'd gone thru the 2 gallons, the bike was idling pretty good. I put in another 6 oz of Seafoam and 3 more gallons of gas, and the it's idling fine now.
I put about 3 oz of Seafoam in the Voyager and the KZ about once a month now. Great stuff!
Greensboro, NC
- Fourtoes
03 Apr 2008 07:54 #203937
by Fourtoes
Replied by Fourtoes on topic sea foam
Typical, not available in the UK!
