- Thank you received: 14
Note to self: Starting bike related
- Bluemeanie
- steell
note to self don't remove the fork drain plugs without releasing the air first :blink: :blink: :blink:
Especially with 5 year old girl sitting 4 feet away in direct line with plug :blush:
She didn't say a word after being drenched with fork oil, she just turned her head and looked at me with a "what a dummy" look on her face :laugh:
Wife didn't hesitate to speak when she saw her though :sick:
- quader98
LMAO big time,i wish i was there...everytime i read it,it makes me laugh
the screw hit me on the shirt and it was like ,ooo ooo ooo while i ran to the drain pan
Post edited by: quader98, at: 2008/01/27 12:24
Post edited by: quader98, at: 2008/01/27 12:26
Ernie from central jersey
82 GPZ 750 R1
looking to part out my 81 KZ750E2
- cafekz750
When changine the fork oil, never assume your friend put the block under the engine as he might have assumed you placed it there.
I removed one cap; no problem. I removed the second cap and the front end slammed down shooting the spacers and fork oil over the bike and into the deepest recesses of the garage.:pinch:
Post edited by: cafekz750, at: 2008/01/28 11:44
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
- pstrbrc
- '81 GPz 1100 project
- Thank you received: 9
(First bike-cb-450 cafe. kicked for 15 minutes, tried bump-starting for another 30, thought I was gonna die. Got a ride home from work, had a friend come with me to look at the bike later, he just about died laughing at me for WEEKS!)
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
- H2RICK
- Is this a fun bike, or what!!!
Note #2 to self: Make DAMN sure that the side stand is all the way forward against the stop BEFORE setting bike on it.
Note #3 to my buddy Paul: Disconnect battery ground FIRST....then disassemble top end AFTER. (Yes, it was messy AND expensive)
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
- ronjones
- Thank you received: 4
:blush:
- ran429
- Master of FREE rides!
Randy, next time you pull bike out of last riding season and winter seasonization, drain tank before filling with new gas. The WATER in the old fuel will make your carbs fill full of water and make the bike not run worth a shibbit!
Valves must be pretty steam cleaned by now though, just like the old airplanes water injection devices lol.
Randy, Change fuel lines also, or atleast make sure there isnt a bunch of crud from the fuel tank clogging them at the filter and fuel outlet of the petckock.
Post edited by: ran429, at: 2008/01/31 19:57
- violentvintagecycles
Take a flashlight the next time you have to jump start your bike and make sure the positive is connected to positive and negative to negative.. 5 seconds of stupidity..
- cafekz750
Next time when lubing the clutch and throttle cable by using the "oil in a bag and gravity" trick; overnight is plenty time judging by the amount of oil under the bike (the cables were still attached).:pinch:
The clutch and throttle control is great now!
