Note to self: Starting bike related
- ran429
- Master of FREE rides!
It will blow out the clutch pressure rod out of the motor and blow oil all over the place while you are looking in a different direction.
When the wife sees my mess i am going to get castrated by a Bobbit special.
- Biquetoast
- King Jeremy The Wicked
Note to self:
Jeremy: don't put two tablespoons of oil in the cylinders (for winterization), then crank the motor (with kick starter) without plugs in.
You should have seen the oil rainbows flying out to both sides of me (it's a twin). There's still an oil stripe on the wall (the other side went out the garage door).
My wife still doesn't know what caused it...
:blush:
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
- GPz750KS
- Thank you received: 2
Use proper tools to remove Fork springs and have plenty of paper towels for bloody nose.:whistle:
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
Note the brown stain above the two windows in the pic.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
- KZ250LTD
- Thank you received: 16
- Bluemeanie
- Thank you received: 14
Post edited by: Bluemeanie, at: 2008/01/26 20:13
- OKC_Kent
- Thank you received: 20
Note to self... (Kinda like KZ250LTD) John, don't start bike with oil cap off and start riding down the street and wonder real quick why right foot is sliding on peg! What a mess, oil all over right side of bike and behind my right leg! And I JUST added oil, now have to add more!! :woohoo: :woohoo:<br><br>Post edited by: Bluemeanie, at: 2008/01/26 20:13
Yessir, been there, done that!:laugh: :laugh:
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- RetroRiceRocketRider
- Thank you received: 29
+1!
Or is that +2? :huh:
Either way, I need a "Note to self" pasted to the ignition switch, because I've done it more than once. :whistle:
- krcrawford29
Kane, when using the pressure washer at car wash, bring plastic bag to cover up pod filters so I don't get carried away and accidently spray the pod filters. Then I will be able to get home before the wife calls all friends.
Sat in the damn parking lot for 15 minutes using full choke and rpms, then 2 minutes at every stop sign.
water/fuel/air mixture?? what's yours???:blush:
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
Jim, when replacing spark pluks, make sure to put the plug wires back on the plugs. I spent 10 minutes and killed my battery, just to realize i hadent put the spark plug wires back on the plugs:pinch: :pinch: :whistle: :whistle: . Oh yea ive forgot to put my oil cap back on. I had this bright idea, to have a "friend" use the electic start to spin the motor over a few times and it shot oil every wich way:pinch: :pinch:
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- mariozappa
- Thank you received: 8
+1 here. Except it was a 750 twin and we had the rotor off the end of the crank with the bolt out.
Almost ALL the oil shot out all over my buddy's Hond@!
It was like it was marking it's territory! :laugh:
1977 KZ650C1
and the KZ650/KZ750 Conversion
- quader98
Ernie from central jersey
82 GPZ 750 R1
looking to part out my 81 KZ750E2
