we want to see your pictures, kz650 with 18" mags
- rstnick
Re: we want to see your pictures, kz650 with 18
25 Jan 2008 06:05
"A set of center axle and shorter forks" would shorten the trail a little, giving you quicker steering.
I've moved the fork tubes up in the tripple clamps as far as my handle bars allow, only about 1/2 inch.
I didn't notice much difference at that small of an adjustment.
I'd think doing one of the above changes (center axle or sliding the fork tubes up) would lower the front, similar to having added an 18" wheel.
Some posts of the subject:
lowering front forks
and some more .
and some more .
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- krcrawford29
25 Jan 2008 06:23
I am thinking on getting the quicker steering. I also want to drop the whole bike like 1-2 inches. Due to funding(lack of) I want to get the front forks swapped first. I am under the assumption that would change the handling characteristics the most, in bang for the bucks anyway.
- hannah1
25 Jan 2008 14:42
Here's a basic program for figuring chassis geometry :
www.rbracing-rsr.com/advchoppercalc.html
I found that leading axle forks are roughly equal to adding about 1.5 degrees to the rake . ie. when inputting known (Kaw specs) for my bike I had to play with the "triple clamp rake" figure to get the numbers to equal factory specs . I couldn't get them correct with offset changes . I've been playing with this because I have a friend making me billet triples for my 550 project , and I am switching to an 18" front wheel and straight forks . I actually like the handling of the 550 , so I am trying to maintain stock geometry .
Post edited by: hannah1, at: 2008/01/25 17:50
Post edited by: hannah1, at: 2008/01/25 17:52
- baldy110
28 Jan 2008 09:55Please Log in or Create an account to join the conversation.
- eslaterb
17 Feb 2008 20:59
Hey krcrawford29, you still looking for mag wheels? Want to trade? I've got an '81 kz550 A standard with mags that I want to swap out for spokes. I'm trying to do the whole cafe racer thing and I think spokes are the way to go.
My only concern is going from an 18" rear wheel to a 16" one. Does anyone know if there will be problems there?
Post edited by: eslaterb, at: 2008/02/18 00:00
Post edited by: eslaterb, at: 2008/02/18 00:57
Thanks,
Eric
Caffeinated 81 KZ550 A
Eric
- hannah1
17 Feb 2008 21:42
16" RW shouldn't be a problem . 18's Fr and Rr seem to give the best proportion and have real good tire choices .
Post edited by: hannah1, at: 2008/02/18 00:43
- madderkaw
18 Feb 2008 08:56
My 650 LTD has a 19 front and a 16 rear mag. The smaller rear was so that they could use a fatter tire and not have to do any chasis modifications.
- krcrawford29
18 Feb 2008 12:02
Hi eslaterb, I might be interested in swapping. Do you know what the widest rear tire is we can fit on the 18" rim without having fitment issues?
Also, are the 81' 550 mags a direct swap???
Post edited by: krcrawford29, at: 2008/02/18 15:04
- slater_kz550
20 Feb 2008 08:19
Right now the tires on my bike are:
Rear 130/90-18
Front 100/90-19
Rear 130/90-18
Front 100/90-19
- Bdog
- Sweep the leg johnny!!!
23 Feb 2008 13:02
gpz's usually use a little wider rim, so a 140 fit's on my rim. Quite a bit better actually.
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- rstnick
27 Mar 2008 15:29
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- Bad Kaw
- Flying Squirell
28 Mar 2008 13:22
This is pretty cool. I'll be interested to see what you think of the 18"...I think you will absolutely notice a handling improvement. Keep pics comin' too, rstnick!
-KR
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
