KZ I.D. ?
- rdgrnr
KZ I.D. ?
14 Aug 2007 13:21
Hello,
I just picked up a 78 650B this past weekend for a project, and I'm not sure how to tell which "B" model it is. I'm fairly new to the KZ's (other than my 1000LTD) so any help would be appreciated.
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- oldkaws4ever
- Have no regrets...... You only live once.
Re: KZ I.D. ?
14 Aug 2007 14:17
there should be a plate somewere on the neck. Get the number and see iff anybody here can help you. For an example mine is KZ650B502139
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- Mellvis
Re: KZ I.D. ?
14 Aug 2007 14:24
Fairly easy. In 78 thhere was 3 choices
Frame numbers are as follows:
KZ650Bxxxxxx is the basic KZ650
KZ650Cxxxxxx is the KZ650 Custom
KZ650Dxxxxxx is the KZ650 SR
the 650's engine will have KZ650Bxxxxxx for the basic and Custom while the SR will have engine ID KZ650Dxxxxxx
- rdgrnr
Re: KZ I.D. ?
14 Aug 2007 16:20
I do have a "B" model based on the frame tag, but I thought there was a B2, and a B3?
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- RonKZ650
Re: KZ I.D. ?
14 Aug 2007 18:41
The number after the B is simply the model year. B1 is 1977, B2 is 1978. B2A is late production 1978, B3 is 1979. So if you have a 1978 it's a B2 or B2A.
- rdgrnr
Re: KZ I.D. ?
15 Aug 2007 10:59
Thanks guys for your help.
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- StreetfighterKz
Re: KZ I.D. ?
15 Aug 2007 12:54
I think the B model had a rear drum brake. I know the C has a rear disk, because that was my starter bike. Can't remember about the D though.
The B normally has spoked wheels and the C has cast but again the D stumps me. I'm sure some 650 owner will correct me if I'm wrong. Gringo?
Later, Doug
Post edited by: StreetfighterKz, at: 2007/08/15 15:59
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
- The Gringo
- ¡Usted no necesita otra motocicleta!
Re: KZ I.D. ?
15 Aug 2007 17:27
You are correct on everything you said Doug. The D model was the SR and like the C model it came with triple disc brakes and mag wheels but the D used a 16" mag on the rear while the C's had 18" wheels. The D's also had painted fenders, a longer seat and no ducktail in the rear and the gas tank was different, sort of a semi coffin style look with a non hinged locking cap that was removeable. The SR's also had the crossover exhaust pipes.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- flht1997
Re: KZ I.D. ?
15 Aug 2007 17:47
hey Ron wasn't the 1978 B2A the California emmission model? that was the impression i was under.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- RonKZ650
Re: KZ I.D. ?
15 Aug 2007 19:28
flht1997 wrote:
I don't think it was just CA, I believe it was the entire USA late production model in 1978. I think it was mostly emissions related though. I have 2 1978 KZ650Bs, one of which is the B2A, both bought new in Colorado. The B2 was made 9/77, B2A 6/78.hey Ron wasn't the 1978 B2A the California emmission model? that was the impression i was under.
- rdgrnr
Re: KZ I.D. ?
15 Aug 2007 20:06
So it is safe to say that mine is a 78 B with a 3/77 production date? I have the spoked rims(no rust)rear drum brake, and no emissions crap like what is on my 79 1000. I was totally surprised on how good of shape this was for what I paid. It really just needs a seat cover, and some side covers, and a new paint job. Has what seemed to be good compression when I turned it over. I took the carbs off to clean them so I don't know if it will run or not. But for what I paid, I figure I can't really lose on this one. Thanks for all the info on the I/D stuff.
OK, not sure now if this is 77 or 78?
Post edited by: rdgrnr, at: 2007/08/16 07:37
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- The Gringo
Re: KZ I.D. ?
16 Aug 2007 04:48
From your description you have a B model from the production date it would be a 77. One way to tell for sure is look at the stator cover, the 77's have 3 allen head screws going thru the cover. The charging system was unique to this model year, they changed starting in 78. Don't be surprised if you soon need to buy a rectifier, 30 years seems to be the lifespan on these there have been several members here, myself included, that have needed to buy one this year.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
