GPz1100 project
- Fossil
GPz1100 project
14 Nov 2006 00:18
This winter I'm swapping over to GSXR750 forks, ZX wheels, 120 and 170 Pirelli Dragons, 310mm rotors, 6 piston calipers, remote reservoir mc and electronc instruments. I'm waiting for a few parts to show up in the mail and I can get started. I took the plunge and sold the stock front end and wheels so there's no turning back. Links from here and the posts and how tos on Lorcan's site give plenty of info for suspension swaps. I will also be converting to 530 chain at the same time.
I need to change a few engine gaskets/seals, new exhaust crush washers, have the pipe sandblasted, repainted and wrapped.
The engine's been on the road for the last 2 years in its present incarnation.
'83 GPz - 1170cc, 10.25:1, 36mm flatslides, Hindle header, cromoly studs, welded crank, undercut transmission and Barnett clutch, on 100% synthetic oil.
Trying to decide exactly what I want to do for rear suspension. I am keeping the stock swingarm, anything else looks like it will lengthen the wheelbase even more. GSXR shocks are supposed to be an easy swap so that's something to look into.
One big advantage of the suspension/wheel swap is the dramatic weight reduction, especially unsprung weight.
Pics when it's together, hopefully for the spring!
Post edited by: Fossil, at: 2006/11/14 03:22
Post edited by: Fossil, at: 2006/12/30 21:27
- Mcdroid
- Gone Kwackers
Re: GPz1100 project
14 Nov 2006 02:11
:woohoo: :woohoo: :woohoo: :woohoo:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Russ
Re: GPz1100 project
19 Nov 2006 08:32
Hi Fossil, Sounds like a good project, I've done similar mods to a Katana 1000 and when looking into doing the same to my Z1000J found that the first model ZZR1100 used a 17 tooth 530 gearbox sprocket with the same spline and a lot of offset which should clear a 170 tire.
ZZR1100
www.jtsprockets.com/52.0.html?&L=0&sel_uid=1145&p=
GPZ1100
www.jtsprockets.com/52.0.html?&L=0&sel_uid=1139&p=
ZZR1100
GPZ1100
- Fossil
Re: GPz1100 project
19 Nov 2006 13:22
Russ, thanks for the tip on the ZZR1100 sprocket. If I got stuck, I was going to weld a new sprocket onto my 630 spline core to get a 530 offset sprocket.
- 1262 Tom
Re: GPz1100 project
19 Nov 2006 16:01
fossil I have completed many of the mods you are considering 10years of trial and error lots of fun I used a zx1200 sprocket bolts right on not offset though,I machined the GSRX wheel to get the chain alignment correct. 170 tire is the largest you can fit in the stock swing arm I only have 3/16 clearance on my chain but its been fine for 5000+ kms GOOD LUCK with your project I will been looking for updates TOM
- Bad Kaw
- Flying Squirell
Re: GPz1100 project
29 Dec 2006 19:15
Fossil,
How 'bout some pics in progress to keep us all motivated over the winter?
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
- Fossil
Re: GPz1100 project
30 Dec 2006 18:26
Bad Kaw wrote:
Will do, should have something to show by the middle of January.
Fossil,
- Bad Kaw
- Flying Squirell
Re: GPz1100 project
31 Dec 2006 15:08
Cool man; I'll be waiting.
78 Kawasaki Z1R
70 Kawasaki KV75
70 Kawasaki KV75
- mark1122
- Keep twisting it
Re: GPz1100 project
02 Jan 2007 09:24
Can't wait to see some pics.It will be fun to follow.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 1262 Tom
Re: GPz1100 project
09 Jan 2007 13:36
hey fossil are you running a hotter cam in your motor it sounds like you have done all your motor mods and now are starting on the chassis.
- Fossil
Re: GPz1100 project
10 Jan 2007 22:15
1262 Tom wrote:
No, just the stock GPz cam - I'm very happy with the power it's putting out and the throttle response as is. I don't plan anymore engine mods, maybe ignition, but not right now. The engine has been on the road like this for 2 years and now it is time for the suspension upgrades. Next year will be paint and powder coat. Pics eventually. Getting a slow start here - gutted and renovated the front room just before Christmas, then Christmas, etc...I'm just really getting to it now.
- Fossil
Re: GPz1100 project
11 Mar 2007 11:55Please Log in or Create an account to join the conversation.
