82 1000 LTD Stock-ish Restoration
- Saablord
06 Jan 2025 21:21 - 06 Jan 2025 21:25
I picked this up about a year ago for $300 as a test mule for KZ1000 EFI parts, but decided to turn it into a daily after my Zero S started having issues (the BMS can apparently spaz out randomly and shut off permanently... its a $700 part and a pathetic failure so it's getting fixed and put up for sale
It's in overall pretty decent condition with sun fade/rot being the main issue as it was sitting out in a field in CO for a few years.
It didn't come with a tank, so I picked up an ebay tank and popped a big ol' dent kzrider.com/forum/6-paint-a-bodywork/620...h-air-bladder#900834 It will still need an internal epoxy coating and some paint/bondo.
The seat that came with the bike was a rusty mess, so I found one in decent condition that only needs a little help...the cover will be pulled to sandblast/paint the tray (for some mild rust)
This is how the bike stands in the garage today. I'm impressed that the chrome is actually in pretty great condition.
I'm stripping off parts and refurbing as I go...
Front sprocket retainers. This is HF chassis paint baked at 140C, which makes it quite durable for rattle can paint.
Stripping off the dry, hard rear tire.
New tires (shinko 999 - long life apparently?). Also 530 chain conversion parts and new handle bars (cant handle the stock ones )
Last edit: 06 Jan 2025 21:25 by Saablord.
- Saablord
Re: 82 1000 LTD Stock-ish Restoration
06 Jan 2025 21:29
The bike did run with very little effort; I just cleaned the bottom of the carb bowls and hot wired the starter etc... most of the electrical will probably get scrapped as its all dry rotted and there's some hackery in the headlight wiring area
Video: photos.app.goo.gl/7ZDU1o1TB1SbvNAH6
06 Jan 2025 23:58
Look forward to seeing what you do with it
- Saablord
11 Jan 2025 08:33 - 11 Jan 2025 08:38
Removed the exhaust and remainder of the rear suspension
Exhaust isnt too bad at all... It needs a clean/polish and a mount tab welded back on
Some of the refurbed parts. The generator cover was quite cracked so I ground them out and will tig weld that.
I've switched to VHT caliper paint in colors aluminum and black as this stuff has solvent resistance and is meant to be baked..so it should be even better than the HF chassis paint. Onwards with the strip and refurb process, I guess!
Last edit: 11 Jan 2025 08:38 by Saablord.
- Saablord
19 Jan 2025 22:19 - 19 Jan 2025 22:30
I modified my engine lift adapter for KZ1000 carb boot hole spacing and finished the rest of the teardown. Carb boots came off without too much hassle with the help of a heat gun and a few applications of silicone rubber restoration spray.
I've been blasting/painting/baking parts for eventual reassembly. VHT is working well and isn't too far off from 2-part paint, in terms of durability, in my opinion.
Drilled the spot welds on the battery box due to the battery acid rust damage
Seat pan is not as clean as I thought, but no big deal to fix.
Wheel bearings removed. These wheels will have to get repainted due to chipped paint.
The frame will fit in the oven at work, so I'll be powder coating that and maybe the wheels too. I'll definitely need to practice as I've never applied it before, so I'll use this batch of parts as test pieces
The gauges were in pretty rough condition, so I went aftermarket to simplify my wiring.
I'm still debating the color scheme for the tank and side covers. It's going to be a solid color, maybe somewhere in the grays/gunmetal? I don't think brighter colors work well with a chromed LTD. Input would be appreciated!
Last edit: 19 Jan 2025 22:30 by Saablord.
The following user(s) said Thank You: Cra-z1
20 Jan 2025 01:41
You are doing some great work on this, should look awesome when done. With regards colour - only you know what "tickles your fancy"
- Saablord
13 Feb 2025 19:59 - 13 Feb 2025 20:03
Ive been adding cerakote and powdercoat parts to the stock pile the past few weeks. Might do one of the wheels tomorrow night, but first I'd need to sort out the hanging and masking for the oven.
Tig'd the generator cover. This is before i goobered on more beads to fill in the low spots
Patched up the exhaust tab
Exhaust cleaned up well besides the battery acid damage i didn't see before
Exhaust air injection blockoff. More cast tig welding Definitely need to shine up that engine to match
And this resto has mutated into two sub-projects
DIY Barrel plating for restoring fasteners kzrider.com/forum/21-tools/621340-diy-barrel-platting
Fitting a hydraulic slave to the stock cover kzrider.com/forum/2-engine/621316-hydrau...for-stock-side-cover
Last edit: 13 Feb 2025 20:03 by Saablord.
The following user(s) said Thank You: Scirocco, Wookie58
- Saablord
15 Mar 2025 19:15
Still chugging along on this as I can with life getting in the way... had the flu one week, and just got the Zero back after ~3 months (what a mess... ended up getting a large refund because the dealer botched the job).
Anyways, I powder coated the front and rear wheels yesterday after chipping away at them for the last couple weeks (blasting masking etc). They're dang near perfect, especially considering this is the 4th (?) time ive done a PC run. Time to get bearings and tires installed.
Only three large tasks left afaik: coating the frame, plating hardware, and new wiring.
16 Mar 2025 02:04
Looks great, you are really moving along with this
The following user(s) said Thank You: Saablord
- Saablord
20 Apr 2025 14:15 - 20 Apr 2025 14:18
Last edit: 20 Apr 2025 14:18 by Saablord.
The following user(s) said Thank You: Gdizard, Wookie58
- Gdizard
20 Apr 2025 14:23
Hello sir,
Do you mind me asking what the price was to powder coat the frame?
Happy Easter !
Happy Easter !
- Saablord
20 Apr 2025 15:50
I did this myself using equipment (oven and powder coating gun) at work. Besides the oven, it was a just a couple pounds of powder ($10/lb) and a harbor freight media blaster and black diamond media ($100) that I already had.
The oven is the tricky/expensive part.
The following user(s) said Thank You: kimchella
