- Thank you received: 334
Another amateur build thread
- Kelly E
15 May 2024 17:45 #899096
by Kelly E
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
Replied by Kelly E on topic Another amateur build thread
Looking forward to seeing the "blundering"
Is that like the fact that it takes 3 times to get anything right, no matter how good you think you are.
1983 Honda CB 1100F
And more
- BruceinOH
- Thank you received: 8
15 May 2024 18:45 #899099
by BruceinOH
Replied by BruceinOH on topic Another amateur build thread
I am glad my misery has a lot of company! I just wish there was more time in the day to get work done…
- Thank you received: 2224
28 May 2024 14:13 #899888
by TexasKZ
Replied by TexasKZ on topic Another amateur build thread
Welp, the first thing I had to do was to take it all apart, because, um, you know, because.
Next I figgered some better suspenders were in order. First, my buddy that I bought them from offered me a GS1100 swingarm that he had saved for a three-wheeler project that he had lost interest in. I decided to have it modified to take KZ style shocks, because, you know, because. I then ordered these--
The following user(s) said Thank You: Rolf1976_KZ900
28 May 2024 14:18 #899890
by TexasKZ
Clearly, something had to be done with those wet-noodle LTD forks. I reckon some 90 wight oil could have done the trick, but why bother with simple and cheap when I could spend a pile of money on something much more complicated, like the forks, triple clamps, stem, handlebars, wheels and complete brake system from a 1995 GPz1100?
28 May 2024 14:23 #899891
by TexasKZ
I am sure some of you wise guys are thinking, well, with that wider rear wheel and the 530 rear sprocket, sumpin aint gonna work so well at the output shaft end of things. If you look closely in the last picture, you may see a front sprocket from and early 1100 Ninja that seems to solve the chain pitch and offset difficulties.
- Thank you received: 2301
28 May 2024 14:34 - 28 May 2024 15:53 #899892
by Wookie58
Replied by Wookie58 on topic Another amateur build thread
That's the spirit, why do. easy ?
how many teeth on that front sprocket (I am running 18/46 which should give me 70mph cruising at around 4500rpm) with a 17" wheel
Last edit: 28 May 2024 15:53 by Wookie58.
28 May 2024 18:54 #899904
by TexasKZ
17 teeth
- asphalt900
- Thank you received: 274
29 May 2024 01:34 #899924
by asphalt900
Replied by asphalt900 on topic Another amateur build thread
The following user(s) said Thank You: slmjim+Z1BEBE, slayer61, Dragbike_Mike, Wookie58
- Rolf1976_KZ900
- Thank you received: 159
29 May 2024 02:19 #899926
by Rolf1976_KZ900
Replied by Rolf1976_KZ900 on topic Another amateur build thread
Oboy that øhlins look nice !
- asphalt900
29 May 2024 03:49 #899928
by asphalt900
I could buy a Wiseco/Wossner piston set, pay for the boring and probably still not have dollars left over compared to the cost of a set of those shocks, ha. Rolf..just noticed You hail from Norway?
- asphalt900
29 May 2024 03:52 #899929
by asphalt900
29 May 2024 06:26 #899939
by TexasKZ
Hmmm. With some gold spray paint, some hot glue and wire hangers, I could modify the GPz wheels so they can identify as Sun rims and spoked wheels……You could always go old school and use spoked wheels. Dig those wild colors! The gold anodized Sun rims would match your Ohlins. Me back in 1999.
