- Thank you received: 394
KZ 440 Basketcase - AKA The "Pig"
- F64
- 81-KZ440D2
07 Apr 2024 20:12 #897366
by F64
81-KZ440-D2.
LIC, NY
Replied by F64 on topic KZ 440 Basketcase - AKA The "Pig"
On my KZ440 the master cylinder didn't allow me enough clamping force so I grabbed a 1993 KLR650 1/2" master cylinder.
It allows me to lock up the fronts but you really have to bleed the air out of it or the lever will bottom out on the handle. The KLR master also allows you to find aftermarket adjustable levers. And it has the brake light switch built into the lever if I recall.
You may have to switch to a chain drive one day.. It's pretty easy but you will have to cut a belt guard mount.
You don't need many electrics on it so it should be easy to wire up.
For a cheap speedometer I use a Sigma bike computer. I actually bought it for the clock but it works as a speedo, trip and total odometer. You may need a lighted version though.I just glued a magnet inside one of the bolt heads for the front brake rotor for the computer's wheel sensor.
sigmasport.com/product/bc-5-0-wr/
I had a tach/hour meter on my bike for awhile but it was digital and slow to update. It good if you are holding a particular rpm for a bit. The sensor wire wraps around a spark plug cable.
www.hardlineproducts.com/product/hourtach-meter/
You may be able to get something from Koso to work.
kosonorthamerica.com/shop/?wpf=test_menu...age=1&wpf_cat=meters
Unfortunately, it's very easy to spend more than the bike is worth. I'm sure most of us will agree.
81-KZ440-D2.
LIC, NY
- sf4t7
- Thank you received: 348
07 Apr 2024 21:40 #897371
by sf4t7
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Replied by sf4t7 on topic KZ 440 Basketcase - AKA The "Pig"
As a friend of mine likes to remind me - "if we were doing this for a living we'd never make any money !"
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
- Michi
- Thank you received: 20
08 Apr 2024 06:23 #897377
by Michi
Maybe a chain broke off and smashed through the sprocket cover, so it was replaced.
KZ440A LTD (1980)
Replied by Michi on topic KZ 440 Basketcase - AKA The "Pig"
Yes, that's strange.I believe the front sprocket (pulley) cover on the left side of the engine is not the right one, and the adjustment in the middle (under the missing cover) is not being used. There appears to no clutch cable going to it, so I guess it was replaced for some reason.
KZ440A LTD (1980)
- Online
- Thank you received: 2301
08 Apr 2024 06:34 #897378
by Wookie58
Replied by Wookie58 on topic KZ 440 Basketcase - AKA The "Pig"
Ain't that the truthUnfortunately, it's very easy to spend more than the bike is worth. I'm sure most of us will agree.
- Nerdy
- Thank you received: 407
08 Apr 2024 06:56 - 08 Apr 2024 06:57 #897379
by Nerdy
That was the first thing to come to mind, but this is a belt drive model. I don't know if a snapped belt would cause the same kind of damage as a thrown chain.
It's odd, though: Partzilla lists a sprocket/pulley cover without the adjustment cover and says it fits the '81 D3:
www.partzilla.com/catalog/kawasaki/motor...rs-81-83-d2-d3-d4-d5
The one with the clutch adjustment is part number 14026-1046 and the one without is 14026-1050. Maybe it was a mid-model-year change.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
Replied by Nerdy on topic KZ 440 Basketcase - AKA The "Pig"
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
Last edit: 08 Apr 2024 06:57 by Nerdy.
- BruceinOH
- Thank you received: 8
09 Apr 2024 16:21 #897425
by BruceinOH
Replied by BruceinOH on topic KZ 440 Basketcase - AKA The "Pig"
Good evening. Again, thank you for the comments.
A quick update / question on the exhaust. The existing bolts holding the exhaust flange were very loose, not much more than hand tight. The header pipe is very loose in the head, is it supposed to have a lot of slop?
The welded bolt appears solid for the moment despite the crack in the weld. I feel my options are to leave it alone as suggested above, or snap it off and try to install a Heli Coil or better yet a Time-Sert so a new 6mm stud can be installed.
The existing flange is held in place with two small welds that I can grind off, but the sleeve (not sure what to call it) does not budge. There is a flair at the end of the header as you can see in the picture.
Thoughts?
Thank you.
Bruce
Thoughts?
Thank you.
Bruce
- sf4t7
09 Apr 2024 20:13 - 09 Apr 2024 20:21 #897433
by sf4t7
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Bruce -
There should be 2 half circle collars that fit against the flare in the tube, and the flanges should be loose on the tubes not welded. See the partzilla diagram for your bike. The factory used the ribbed flanges but a lot of aftermarket pipes use the flat flange like yours has. Both would use the split collars to keep the pipes tight to the head. And there are copper gaskets that go between the pipe and the head to keep a seal.
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Last edit: 09 Apr 2024 20:21 by sf4t7.
- Michi
10 Apr 2024 09:38 #897448
by Michi
KZ440A LTD (1980)
^Exactly right.
Regarding what you should do with the welding on bolts, it's great you have the helicoil or timesert to fall back on, but what I would do in that situation is try and go with the welded on bolt, once I have the exhaust flange collars and steel collets (and copper/fibre gaskets) in hand. You never know - there might be enough exposed thread on the welded bolt to fit the exhaust properly without having to take on more work. Then again, if you encounter problems from what the previous owner did, then just cut off that bolt and helicoil/retap or whatever (in which you'll need a new exhaust bolt).
The little tab welded onto the exhaust header is silly - just grind that off.
Here's how the exhaust attaches:
images.cmsnl.com/img/partslists/kawasaki...kar09689917_b2f7.gif
KZ440A LTD (1980)
- BruceinOH
17 Apr 2024 19:20 #897766
by BruceinOH
- BruceinOH
17 Apr 2024 19:47 #897769
by BruceinOH
- Nebr_Rex
- Thank you received: 299
18 Apr 2024 14:55 #897802
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic KZ 440 Basketcase - AKA The "Pig"
all wires inside.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- BruceinOH
18 Apr 2024 18:26 #897815
by BruceinOH
Thank you.
Sorry for all the dumb questions. The repair manual provides some guidance but having to undo what I can see is wrong without seeing the way it should be is proving difficult.
I was able to reroute most of the harness so that it rides along the inside of the frame rails. The cut wires for the prior post need to be fixed before I move forward, so I hope the bullet connectors come in soon.
As I go through the harness I keep finding little blue packets that have crimp connectors. They kinda line up with the wiring diagram so I assume that is factory? The problem is where the loom has been unwrapped the blue tape is falling apart.
Thank you.
Thank you.
