Z650 / GPz engined Restomod
  • Bevelhead
  • Bevelhead's Avatar Topic Author
Re: Z650 / GPz engined Restomod
16 Apr 2025 08:32
#911360
As an aside, I am following another Z650 that my friend is building. It's where my GPz 750R1 engine came from, a bike which hadn't run for 25 years. The reason that engine was 'spare' was because this Z650 is undergoing an major make over. Its being rebuilt as a 90's era street fighter, powered by a GPz750 Turbo engine, taken out to 810cc and fitted with a bigger turbo, long with suspension and brakes from the 90's. The front end is from a ZXR750 in thick billet yolks, while the swing arm is from a ZRX1200. The latter not quite 90's, but close enough..
  • Sixten
  • Sixten's Avatar
18 Apr 2025 00:46
#911436
What wheels are those in the first picture?
  • Bevelhead
18 Apr 2025 07:48
#911449
I think they are CMA wheels, an upgrade from the original heavy mag wheels back in the 80's.
  • Bevelhead
25 Apr 2025 14:40
#911740
Brake side rear set done, now needs to be hard anodised, but that can wait..
  • Bevelhead
29 Apr 2025 03:43
#911850
Finally got tyres on the R6 wheels, front wheel went in, but the rear will have to wait as the cush rubbers I bought aren't the correct ones. At least I fitted the aftermarket stainless pillion grab handles. I wasn't going to bother fitting those, but pushing my other Z650B backwards up a slight incline, convinced me that they are needed.
  • kimchella
  • kimchella's Avatar
29 Apr 2025 11:49
#911878
Looking great👍👍
KZ650B1 frame number 225
New Zealand
  • Bevelhead
29 Apr 2025 15:17
#911882
Cheers, finally got both wheels fitted today, along with the Dyna coils...
  • kimchella
29 Apr 2025 15:29
#911883
Very nice, always great inspiration to get everything back together when the wheels are in place 😁👍
New Zealand
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
29 Apr 2025 16:42 - 29 Apr 2025 16:45
#911886
I would replace the coil mount aluminum spacer with some PVC spacer, just my 2 cents.........
You risk a short cut to the frame mount on the hot wire coil connector screw under some rare cirumstance and lack of clearance!
Nice wheels you choose, i love it. See the next future BOTM.........
Last edit: 29 Apr 2025 16:45 by Scirocco.
  • sf4t7
  • sf4t7's Avatar
29 Apr 2025 17:32
#911889
I agree, insurance against shorts. I found some plastic spacers at the local hardware store. I think they are 1/2" OD with a 1/4" ID.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
The following user(s) said Thank You: kimchella
  • Bevelhead
30 Apr 2025 11:21
#911914
Indeed, the spacers are too close to the low tension screws. I got round that last time by filing a flat on each spacer to give enough clearance.
  • StreetfighterKz
  • StreetfighterKz's Avatar
30 Apr 2025 12:21
#911915
I made aluminum spacers for the Dyna coils on my 650 project.  I covered them with heat-shrink tubing to provide insulation from shorting out.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: Bevelhead, Gdizard, kimchella
