new to me 1978 KZ 1000
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: new to me 1978 KZ 1000
11 Nov 2024 12:09
#905976
You might want to start with a set of "air correctors" from Zed1015 and then go from there, he will best advise on jet sizes
  • Treetall
  • Treetall's Avatar Topic Author
12 Nov 2024 10:31
#905993
Thanks Wookie
I'll give him a shout.
  • Treetall
14 Nov 2024 18:45
#906059
I've decided to go with electronic ignition. I'm having issues with 2,3 cyl coil.
With all the reading I've done on this site. I should go with a DynaTek  DS2-1 electronic ignition and a set of DC-1 coils 3 ohm ( the green ones).
Am I correct in all my reading/ studying !?
Never had any luck with knock offs, so we won't go there.
Also, where's a good place to get a Shindengen SH775 R/R.  Looked all over the net, can't seem to find an authentic one.
Unless I'm looking with my eyes closed, like my wife likes to say!
Thanks
  • Treetall
18 Nov 2024 17:02
#906222
Thanks
Bump
  • Buzz Nichols
  • Buzz Nichols's Avatar
18 Nov 2024 21:59
#906229
Ed (Nessism) seems to be the guy who always knows where to procure the Shindengen SH775 RR's. He's also the guy who can best explain why it's the superior RR.
1978 KZ1000 LTD
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
19 Nov 2024 00:38
#906233
The DS2-1 with 3 ohm coils should get the job done
  • Injected
  • Injected's Avatar
19 Nov 2024 08:30 - 19 Nov 2024 08:41
#906237
I bought a used genuine SH775 that was on a 2013 Polaris RZR800 ATV off Ebay, it was about $100 Canadian all in. I have been using it on my 750 for 4 seasons with no issues.
I made up my own mini harness with cheap plug ends off of Ebay as well. Search "voltage rectifier connector for 675 1050R T2500676" at the time they were less than $20 for the set.
Search for a wire diagram on here.
If you have a local motorcycle/atv salvage you could check there, would be cheaper but you have to bring a meter to check it on the spot.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
Last edit: 19 Nov 2024 08:41 by Injected. Reason: info
  • Treetall
20 Nov 2024 22:36
#906274
Thanks guys.
Just wanted to make sure.
  • Nessism
  • Nessism's Avatar
21 Nov 2024 07:59
#906275
To find a SH775 search eBay for "710001103" or "4012941".  Toggle "used" and sort by price.  Look for one in decent shape that has "SH775" printed on the top fin.  Inspect the photos carefully to make sure the plastic connector isn't damaged.  That's the most common problem, other than corrosion, that I've found.  I've bought and resold dozens of them.  I have a couple right now if you can't find one on ebay.  I test them on my 750, and have never found one that didn't work properly.  They are very robust.
  • Treetall
21 Nov 2024 21:50
#906283
Thanks Ed
I looked around a bit on line, but didn’t see any with the SH775 on the top fin. Like you’ve mentioned before.
i will look around some more.
  • Treetall
22 Feb 2025 20:01
#909306
Well, the ole girl runs like a scalded cat but on three legs!
Number 2 cyl. isn't firing. I dug out my laser thermometer and it shows pretty much cold compared to the others.  1and 3 would show 300+F and #2 shows 100* F
I put in a Dynatek DS2-1, The coils are working good after all. I just couldn't seem to get a good ohm reading before.
I've got good compression all across at 100 lbs
I've got good spark on #2 and I switched plug wires with # 3 and still have nothing.
So this would point to the carb, correct?!  I've had the carbs off a bunch of times, and have completely torn apart #2 at least twice.
I've checked and set the float levels as per manual and also mechanically synced the carbs as per man. as well.
I've sprayed carb cleaner through every possible orifice that I could, and in every direction. front to back , top to bottom etc.
I seem to have juice coming out where it's supposed to.
I've ran a small soft wire in all the openings, and ran it  in until it dead ended or changed direction.
I would have used carb dip. But I was told in the Auto Parts store that we can't get Carb dip in good ole Canada any more!
So any suggestions would be more than appreciated. My forehead is beet red, and the wall has a big dent in it!
Thanks in advance!
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 Feb 2025 20:41
#909308
Sounds like a bad plug wire connection. Do you have a timing light?
