1973 Z1 rebuild
Re: 1973 Z1 rebuild
29 Jun 2022 00:57
The following user(s) said Thank You: 750 R1
- Wheelhop
Re: 1973 Z1 rebuild
29 Jun 2022 07:57
Black Frames Matter!!
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
The following user(s) said Thank You: willemZ900, slayer61, Wookie58
- Shankkole
Re: 1973 Z1 rebuild
29 Jun 2022 08:46
I cannot find any pics
I have seen black frames with one coat of color scheme matching KANDY on top.
You don't see the color, it just glows a little more like an high definition Black with a deep undercoat.
But so you know I'm a bastard on color (not a stock paint job at my house,on anything except the wifes daily) as my z chop frame shows.
Re: 1973 Z1 rebuild
29 Jun 2022 08:55I think with chop's, trikes and any other "full custom" build the rule book goes out of the window. Especially with most chop's the frame is the dominant feature rather than the bodyworkI cannot find any pics
Re: 1973 Z1 rebuild
29 Jun 2022 18:34
I would vote for black, but if you want to stay as close as possible to the original black....it wasn't gloss. And it wasn't semi gloss. Somewhere in between.
- blackozvet
Re: 1973 Z1 rebuild
05 Jul 2022 19:49
Time for an update - I have been busy online finding stuff. The wait continues on the de-chroming (they were still waiting on chemicals)
I have got the complete gasket set, valve guide seals and the later model brass neutral switch (which fits the trans cover perfectly)
I have ordered a separate Cometic MLS head gasket for the larger sleeves/pistons.
The Mrs got me a new seat for my birthday !
Still in the process of moving stuff around in the workshop, need to get the bike stand in a position where the bike can get up and down the ramp when its rolling.
1973 Z1 900 Kawasaki
- 750 R1
Re: 1973 Z1 rebuild
06 Jul 2022 15:51
Make sure that head and block are baby bum smooth if using the MLS gaskets...
Bikes coming along nicely,the missus is a keeper !
- Skidmark
Re: 1973 Z1 rebuild
06 Jul 2022 18:19
Beautiful seat!
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- blackozvet
Re: 1973 Z1 rebuild
06 Jul 2022 19:29I usually scrub them with brake cleaner till you can see the machining grooves.Make sure that head and block are baby bum smooth if using the MLS gaskets...
- blackozvet
Re: 1973 Z1 rebuild
06 Jul 2022 19:32its the PMC made one.Beautiful seat!
- blackozvet
Re: 1973 Z1 rebuild
08 Jul 2022 01:53
I spent a few hours wet sanding the Akront rims to get rid of corrosion marks and grime, finishing with 1200 and then polish.
They are looking a bit fresher than they did before !
Also got the Cometic MLS head gasket that will suit the 72.5 mm pistons.
Re: 1973 Z1 rebuild
08 Jul 2022 02:31
