1973 Z1 rebuild
  • blackozvet
  • blackozvet's Avatar Topic Author
Re: 1973 Z1 rebuild
09 Aug 2022 06:44
#871919
Is that rear rim a Takasago?  The key flag may have come from a KLR.  I had one with mine.
The rims are both Akront (Spain) alloy rims.
1973 Z1 900 Kawasaki
  • hardrockminer
  • hardrockminer's Avatar
Re: 1973 Z1 rebuild
09 Aug 2022 19:34
#871951
OK, thanks.  I was pretty sure the rear wasn't OEM.
  • blackozvet
Re: 1973 Z1 rebuild
10 Aug 2022 04:55
#871962
While I am waiting for parts at the Powdercoater and Hydroblaster I have tried to give the alloy polishing a break for a while to allow my fingers to recover, so I have started doing what needs to be done behind the engine covers.
First up, the inner sprocket cover needs the 3 seals punched out and replaced with new ones, a clean up and sorting out some fasteners, then screwed on with a fresh gasket.  The new neural switch gets bolted in too.
Now while I'm peeking behind the dynamo cover I realise that to re fit the starter I am going to need the starter idle gears (that connect the starter gear to the ring gear) and they were probably thrown out years ago.
I put a call out on the FB Z1 group and someone local to me actually has a spare one in their shed, so I make a visit today and a starter gear is obtained, good score !  I had to order the connecting pin from the local Kawasaki dealer and that will be a 4 week wait.
  • hardrockminer
Re: 1973 Z1 rebuild
10 Aug 2022 06:07
#871963
There should be a thin o ring on your final output shaft, on the outboard side of the bearing.
The following user(s) said Thank You: blackozvet
  • Cra-z1
  • Cra-z1's Avatar
Re: 1973 Z1 rebuild
10 Aug 2022 07:24 - 10 Aug 2022 07:25
#871973
I was just thinking of mentioning that o-ring, between the bearing and the sprocket spacer. Good call Hardrock.
Last edit: 10 Aug 2022 07:25 by Cra-z1.
  • blackozvet
Re: 1973 Z1 rebuild
10 Aug 2022 20:05
#872020
well you learn something new everyday, over the years I never knew there was an O ring in there !
  • blackozvet
Re: 1973 Z1 rebuild
10 Aug 2022 20:09 - 10 Aug 2022 20:10
#872021
Some of the bigger parts of the project are now getting done - the powdercoating is done !
Last edit: 10 Aug 2022 20:10 by blackozvet.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: 1973 Z1 rebuild
10 Aug 2022 23:55
#872027
You are making great progress, it will look superb with the new bodywork
  • blackozvet
Re: 1973 Z1 rebuild
11 Aug 2022 00:25
#872029
Its been all go today - I also got the head and barrel back from hydroblast.
I have already masked up and painted the cylinder barrel in black satin.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: 1973 Z1 rebuild
11 Aug 2022 03:53
#872032
Don´t forget to flush an clean the oil transfer ports in head!
  • blackozvet
Re: 1973 Z1 rebuild
17 Aug 2022 22:14
#872419
yes, the final clean will have to wait coz I pulled the helicoil out of one of the plug holes.
  • blackozvet
Re: 1973 Z1 rebuild
17 Aug 2022 23:17
#872421
I have been a bit distracted with other stuff (the hillclimb car) but have still managed to get some parts polished and painted.
When I got the head back from hydroblasting I realised that when the end spark plug was pulled out it took the helicoil with it !  I didnt have any 14mm inserts so I ordered a spark plug repair kit -  when the kit arrived it had very short inserts so that was a waste of time.  Will have to drive down to the industrial bearing place to get the correct length ones.
I cleaned up the front disc, it was a rusty piece of junk, and gave it a coat of high temp silver.
dropped the adaptor and disc on the wheel just for a self satisfying look.
