And finally, Wookie's 82 begins !
- sf4t7
Re: And finally, Wookie's 82 begins !
11 Sep 2023 14:20
Wookie, that peg setup is cool ! The heel guards scream function over form, maybe you can make some out of similar thickness aluminum plate that have a little more appeal. (Unfortunately you probably can't do that on your new lathe) I like your wheel assembly fixture, looks easier than the "put your foot under the tire and try to line up the axle" method.
Scotty
Scotty
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- Rolf1976_KZ900
11 Sep 2023 15:05
Impressive work !! this bike is going to be cool !
11 Sep 2023 16:19
Thanks guys, it's been in my head a long time and I just want it to be " the best I can make it" I have been learning many new skills along the way
- Nerdy
12 Sep 2023 11:35If they're ugly and they work, they're not ugly.
This is a fantastic project! I really appreciate the pics.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
12 Sep 2023 11:58I am unsure which way to go yet, the "right" one would be difficult to replicate as it has a pronounced curve around the master cylinder and I have to ask myself "how much extra work do I want to create" I think once they are anodised black they will kind of slink back into the shadows
17 Sep 2023 10:30
So I have been finishing up the foot controls this weekend, sorted the gearshift (I was going to buy a GPZ part but when I looked at it, it appears it's just a pice of flat steel welded to the end of a normal lever so that's what I did) needed a few bushings and spacers to get it working correctly (on the Yamaha they came from the shift rod runs behind the lever and frame spar) I just couldn't live with those ugly heal guards so I "bit the bullet" and made alternatives which I like a lot more (I could have just junked them but they are there for a reason) I just need to make a couple of spacers for the brake pedal and master cyl
The following user(s) said Thank You: sf4t7, howardhb, Kelly E
- sf4t7
17 Sep 2023 19:33
Wookie - those new heel guards look much better, they match the shape of the pedal brackets. Nice work.
Scotty
Scotty
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- Stereordinary
17 Sep 2023 21:23
I just noticed that you've done a monoshock conversion. Amazing!
A breeze from the west.
18 Sep 2023 05:03 - 18 Sep 2023 05:03
Last edit: 18 Sep 2023 05:03 by TexasKZ.
23 Sep 2023 11:44
Have wrapped up the foot controls today, spacers for the brake pedal and rear reservoir. This has tucked in nicely behind the sidepanel but I had to go through the brace with the hose. I have welded a steel tube through to maintain strength and made an ally joining piece for the hose. Now onto the exhaust
The following user(s) said Thank You: RBRKZ, Rolf1976_KZ900
- Rolf1976_KZ900
23 Sep 2023 12:52
Nice work ! i can not weld ,but i have to learn it ,because in the near future im planning to make a project like this when i get a proper garage.
23 Sep 2023 15:29Looking forward to seeing what you create RolfNice work ! i can not weld ,but i have to learn it ,because in the near future im planning to make a project like this when i get a proper garage.
