And so it begins... 1976 KZ750B Twin barn find project.
- KZJOE900
- Admin
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- Kidkawie
- I bleed premix
- Thank you received: 245
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
- Thank you received: 2817
- Thank you received: 1918
- Skidmark
- Thank you received: 260
Retired gearhead
'81 KZ-750 E2
'87 Suzuki Savage 650 Street Tracker
- Polish
Have you checked Classic Octane YouTube Channel? He has restored a similar bike.
JL
1979 Honda CB400T Cafe Racer (current ride)
1982 KZ750 LTD (current project)
- soulsrgn
DoctoRot wrote: I totally get just trying to make it run but FYI the stock ignition system on the 750 B is pretty lazy. if you can find the electronic ignition setup from a late model 750 twin or a 440 twin the bike will be way happier with more timing and more advance.
Thanks for this advice. I was hoping to find a suitable electronic ignition if this thing runs half-way normal after some replacement stock parts. I wondered if later model 440 twin igninitions would work.
1976 KZ 750 Twin
- soulsrgn
I appreciate all the advice on tank clean-out. Lot's of great suggestions. I'll be honest, I was super curious about the cleaning grade vinegar. I can't believe I've been working on old stuff for this long, and hadn't heard of this technique. So I wanted to try it and I did!
I removed the fuel petcock and plugged it with a rubber expansion plug. Then I put the tank in a plastic tote to contain any leaks. I tossed exactly 30 sharp and pointy construction screws in there for agitation. I filled the tank to the lip of the cap, and let it sit under the workbench for a couple days.
After the weekend, I pulled the tank out, strained off a couple gallons of vinegar in to an oil pan, closed the cap, and shock the crap out of it for about 10 minutes. Then I strained off the rest of the vinegar to inspect the tank. I forgot to take pics of the inside of the tank, but there was a lot of clean bare metal with a bunch of flaky liner bits laying around in there. This tank is really solid, no leaks, no obvious soft spots or excessive rust damage. So I decided the vinegar was doing it's thing. I re-filled the tank with the same strained vinegar, topped it off, closed the cap, and back in the tote and under the bench it sits. Below are the contents of the strainer, and one large chunk of old tank liner I pulled out of there.
I'm pretty confident in the vinegar at this point, I'm curious to see the end result. I used the same vinegar on the chain I'll share in a later post.
1976 KZ 750 Twin
- soulsrgn
Pulled lighting, controls, carbs, air box, and brake assemblies. I'll soon be wrestling with each I suppose. I left wiring and electronics in tact in order to get at least the skeleton of this thing to run...
1976 KZ 750 Twin
- soulsrgn
I got the ignition parts swapped out. Had to come up with replace points and condenser machine screws, but that wasn't so hard. Here's pics. Hooray me!
1976 KZ 750 Twin
- Polish
- soulsrgn
Amongst other things, I pulled the chain from bike. Below the first picture is right after I set the greasy and crusty chain in a shallow bath of the same vinegar I used in the tank.
I filled the pan enough to submerge the chain, and let it sit overnight. After a 24hr soak, some random flipping and scrubbing with a toothbrush sized wire brush, this is what you have.
Even in this condition, there were still a couple stiff links. So back in the bath it goes. It's napping there now and will be until tomorrow. I'll take some pics of the final product. I know chains are relatively cheap, and nice new o-ring chains are nice, but why toss it if I don't have to? The bike is low miles for it's age, the chain shows little wear or any damage from age, if I can clean it up and re-lubricate it, I see no reason not to use it. I'll keep an eye on it. The bike is far from a performance machine by today's standards, and I don't plan on excessively beating on it.
1976 KZ 750 Twin
