Katit's 1978 KZ650 project 08 Sep 2021 20:22 #855028
  • katit
  • katit's Avatar Topic Author
  • Thank you received: 48
Little more assembly tonight. Each bolt had to be thread-chased because after plating they get some more "meat" on threads.
Oiled for proper torque. Bottom assembled and engine flipped upside! Almost done (bottom end)
Katit's 1978 KZ650 project 08 Sep 2021 20:39 #855029
  • Thank you received: 2829
I don't understand your statement "oiled for proper torque."  The Kawasaki Service Manual says the torque values are for "dry solvent-cleaned threads"; that would be different than oiled threads wouldn't it?  Ed
The following user(s) said Thank You: katit
Last edit: by 650ed.
Katit's 1978 KZ650 project 08 Sep 2021 21:05 #855030
  • katit
I guess you are right. I only did it for oil pan bolts. All others were dry torqued but for some reason I decided to do it with those. No big deal. Even if I over torqued a little not going to hurt in this spot. For future will keep it in mind. I didn’t read this in FSM. Thank you!
Katit's 1978 KZ650 project 17 Sep 2021 08:27 #855403
  • katit
Some more progress. Engine is pretty much assembled except for head, but head needs some work.
Rebuilt clutch activator using NOS parts. Originals had some where which would cause stickyness.
Last edit: by katit.
Katit's 1978 KZ650 project 19 Sep 2021 17:32 #855492
  • katit
Cylinders on. Used @gazzz trick with plastic strips and zip ties to hold rings. Just used 14ga romex wire (with insulation) to make u-shaped piston holders. Quick and worked like a charm.
Now to the head. This is head I got from eBay, everything checks out, but I am going to replace valve guides and valves. Since I have them and those that came with a head had some wear.
Positioned head on "angled" fixture and made sure all guides perpendicular. Now it will be really easy to press in/out. Especially after getting head hot in a oven.
Katit's 1978 KZ650 project 19 Sep 2021 17:36 #855493
  • katit
Made plugs for emissions bypass holes. Holes measured ~9mm. So I just went straight with M10 1.25 tap. Found two bolts, 5 minutes with angle grinder and 5 minutes on a lathe and my plugs ready.
Any suggestion on what to use to seal it? Same tree bond as for engine? Put on threads?
Katit's 1978 KZ650 project 19 Sep 2021 17:51 #855494
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2677
Great job on your project!  And thanks for all the great photos.
Just a reminder, in case you didn't realize, but the valve seats will need to be cut after installing new valve guides..
Good luck
Katit's 1978 KZ650 project 19 Sep 2021 17:57 #855495
  • katit
Thanks! And yes, absolutely. I got all the neway cutters waiting. Right now (uninstalled) guides feel just right with new valves. I didn't measure but they fit, so.. Can't imagine them being "tight". It's APE performance bronze guides. Don't plan on rimming those unless there going to be stickyness.
I really hope it will work out without shortening valves.
Katit's 1978 KZ650 project 19 Sep 2021 19:13 #855501
  • Skidmark
  • Skidmark's Avatar
  • Thank you received: 260
I needed my new valves ground shorter.  Found a car engine builder with a valve grinder machine and he charged $10 each (including removal and reinstallation).
Retired gearhead
'81 KZ-750 E2
'87 Suzuki Savage 650 Street Tracker
Katit's 1978 KZ650 project 20 Sep 2021 08:50 #855524
  • katit
I think if it's going to be needed I will just specify exact measurement by how much to shorten and bring actual valves to the shop
Katit's 1978 KZ650 project 22 Sep 2021 18:37 #855639
  • katit
Cleaned head via soda blasting. Then pressure washed with water. Then air blow every hole. Then pressure washed again. Will do more cleaning later when done with valves.
Conveniently enough I had this angled mount, not sure what it called. Guy who sold me lathe/mill gave it as a part of a deal 5 years ago? Never knew why I need it and now it's perfect! Dialed it to make valve holes vertical when head lays on it.
Heated head to about 350F in oven.
Pressed out old valve guides. Which is easy, you just remove them.
Now installing new ones? Hmm. I really scared of over-pressing. So, what I did - I machined sleeve for my pressing shaft. This way this sleeve will stop on a head body making it precise and positive stop when new stems will be pressed in.
On a side note - those valve guides needed. Old ones even with new valves I can feel some play even by hand, so it's good idea. OTOH - camshaft clearances good. So, if I don't f-up something, it will be a good head.
P.S. Hmmm reading about dry ice.. Word is, if I heat up head and get guides cold with dry ice - they should simply drop into their hole. True? If so, I'd rather get some dry ice than trying to press them in.
Katit's 1978 KZ650 project 22 Sep 2021 18:57 #855641
  • Skidmark
  • Skidmark's Avatar
The device you are referring to is a sine plate.  Very handy!
Retired gearhead
'81 KZ-750 E2
