Best gearing ratio
- Bowserpup32
Best gearing ratio
25 Jan 2020 15:40
What up guys. I’m replacing both my rear sprocket and front sprocket. Buying new since old ones are chewed up. Looking for a little more off the line vs at the high end. Any feedback here would be great. Ideas and or suggestions needed. 1978 kz1000a2. Basically stock right now.
Re: Best gearing ratio
25 Jan 2020 16:47 - 25 Jan 2020 17:01
What chain Setup do you want to go? 630 or 530?
For a 630 chain 15/35 urban area or 15/33 for long highway rides.
kzrider.com/forum/5-chassis/612176-gear-ratios-for-530-chains
or calculate your own gear Ratio
www.rbracing-rsr.com/chainlength.html
Last edit: 25 Jan 2020 17:01 by Scirocco.
25 Jan 2020 17:11
If you buy new sprockets buy a new chain. An old chain will rather quickly wear new sprockets, and old sprockets will quickly wear out a new chain. That's why chain and sprockets should be replaced as a set. Ed
The following user(s) said Thank You: Scirocco
25 Jan 2020 17:58
All sound advise
My 78 LTD came geared 15 / 33 Remember it has a 16 inch rear wheel
Most 18 inch wheel bikes I have seen commonly came 15 / 35
Avoid going with a 14 tooth front gear and go with the larger rear sprocket.
If you have shit loads of power like a turbo you can run a 16 / 33
25 Jan 2020 18:10
530 chain/sprockets is the way to go. 630 is for guys stuck on nostalgia.
- urankjj
25 Jan 2020 18:33
If you want a little more off the line, I think that the easiest would be to drop a tooth from the front sprocket. Keep in mind that will move the rear wheel back slightly on the swingarm. If you want even more,(off the line), drop a front tooth and add 1 or 2 teeth to the rear sprocket. Again this would change wheel and tire size clearance to swingarm and related parts.
25 Jan 2020 18:50Street Fighter LTD wrote: All sound advise
My 78 LTD came geared 15 / 33 Dave
Got worried for a minute. I have been following this post and was worried I screwed up my ratio, I when out and looked at my '78 1000 LTD with a 16" rear 130/90 tire... I have 15 / 32... I was looking for a harder launch... Was I right or wrong...
- urankjj
25 Jan 2020 19:17
Did you get a harder launch with 15 / 32. I f not try 14 / 32, and you probably will.
25 Jan 2020 19:26
Can't tell, I changed out the sprocket years ago and have no way to compare, I just noticed most suggestions swap the front sprocket...
- Bowserpup32
26 Jan 2020 05:04
I already bought a new 530 o/ring chain. I will measure my rear tire and get back to y’all since reading this sounds like will be a determining factor.
26 Jan 2020 05:59
15 / 32 is more of a highway ratio than 15 / 33 or 35
15 , 35 would make it peppier down low
Everyone and their brother including me has tried a 14 tooth front sprocket and it works fine , just harder on the chain life
That's why a larger rear sprocket is preferable but a costlier swap
But also as suggested a 530 swap is the modern way to go
26 Jan 2020 06:09 - 26 Jan 2020 06:14
Also, with a 530 chain, you will likely need to go with the largest front sprocket available to insure plenty of clearance between the chain and swingarm pivot. A 14 tooth sprocket for a 530 chain will be smaller in diameter than a 14 tooth sprocket for a 630 chain.
Here you can compare different combinations.
www.gearingcommander.com
Last edit: 26 Jan 2020 06:14 by TexasKZ.
