Best gearing ratio
  • Bowserpup32
  • Bowserpup32's Avatar Topic Author
Re: Best gearing ratio
26 Jan 2020 13:59
#817969
Ok....so far I’m seeing that a 15/35 would be better for off the line. I’m using a 530 chain along with my 16” wheel which I verified. Just wanted to confirm before I commit.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
26 Jan 2020 14:10
#817976
Bowserpup32 wrote: Ok....so far I’m seeing that a 15/35 would be better for off the line. I’m using a 530 chain along with my 16” wheel which I verified. Just wanted to confirm before I commit.
15 / 35 is based on 630 chain 1/ 2.33 I think
just do the math for the ratio and convert to whatever is the equivalent ratio in 530 chain sprocket sizes
  • Mikaw
  • Mikaw's Avatar
26 Jan 2020 16:05
#817984
Thanks StreetFighter.
Can someone please state the advantage of converting to 530 setup.
  • hardrockminer
  • hardrockminer's Avatar
26 Jan 2020 16:32
#817987
Mikaw wrote: Thanks StreetFighter.
Weight and maybe cost?
  • Mikaw
  • Mikaw's Avatar
26 Jan 2020 16:36
#817988
Is it a rotating mass thing. The lighter something is the fast you can get it spinning
  • Moderator
  • Moderator
26 Jan 2020 18:05
#817999
Lighter and less rotating mass
  • Mikaw
  • Mikaw's Avatar
26 Jan 2020 19:21
#818000
Found this in a post from 2007;
530 X-Ring chain and 630 O-Ring chain are virtually the same width - they both use 3/8 wide rollers (that's the 30 in the 530 and 630 - that means 3/8" width for the rollers).
Spacing isn't an issue provided you install a spacer washer on the front sprocket.
The benefits for 530 over 630 are considerable - cheaper, better selection, better wearing, and lighter. The cons - really none - except for a couple of bikes where there isn't a readily available 530 rear sprocket (KZ900 LTD uses a unique rear sprocket - so no 530 rears are readily avialable).
The following user(s) said Thank You: Street Fighter LTD, hardrockminer
