KZ900 - updated suspension
  • Mikaw
  • Mikaw's Avatar
Re: KZ900 - updated suspension
24 Jan 2020 12:08
#817762
I’m at work. I have an LTD I can get you photos of when I get home
  • Mikaw
  • Mikaw's Avatar
24 Jan 2020 12:16
#817764
Here is something till I can get you some from mine
  • Mikaw
  • Mikaw's Avatar
24 Jan 2020 12:55
#817766
Just found this... I will do more research
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
24 Jan 2020 13:49
#817768
The axle Diameter for a ZX6R and ZX9R front and rear end is 25 mm
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
24 Jan 2020 13:54
#817770
My ZX9R donor bike front end comes with an Spiegler SB upper triple yoke.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
24 Jan 2020 14:00 - 24 Jan 2020 14:04
#817771
For the rear MC i made a bolt on aluminum adapter plate for my Tarozzi foot rest with a direct linkage and a hydraulic brake light Switch for the Banjo bolt.
Did the same break light Switch on the front end.
Last edit: 24 Jan 2020 14:04 by Scirocco.
  • Mikaw
  • Mikaw's Avatar
24 Jan 2020 15:40
#817786
Nice work Scirocco
  • Mikaw
  • Mikaw's Avatar
24 Jan 2020 15:43
#817788
Supprised it’s just plate welded to the frame tube
  • Dr. Gamma
  • Dr. Gamma's Avatar
24 Jan 2020 15:48
#817791
Your brake linkage is real close to the setup I use on my Kz1000.
There are a few master cylinders out there that you can just weld two simple flat brackets to the frame tube to mount them. I like plain and simple ways of doing things myself!!!
I mounted the reservoir for the master cylinder to the side of my battery box under the side cover.
1986 RG500G 2 stroke terror.
  • Bama704
  • Bama704's Avatar Topic Author
26 Jan 2020 06:44
#817935
Thanks for those pics of the master, will have to do some mock ups.
For my issue with the chain hitting the tire a member on another forum suggested my hub could be incorrect and after looking at partzilla I do have the incorrect hub. Gotta love buying secondary. New and correct hub being sent via ebay and should arrive Friday. Hoping to know more after that, but will for sure have to buy another new rear sprocket.
1977 KZ900
Carbs are late model 1975 28mm
  • Bulletkz
  • Bulletkz's Avatar
26 Jan 2020 07:30
#817938
I used a gsxr aftermarket rearsets they have a mount for the master.
I used a brake light switch bolt.
For the handlebar mounts I just bought a set of stock Kawasaki bar clamps and used them on the bottom and bolted though the upper tree.
For the stainless brake hose I found used triumph 675 naked lines and a zx10 rear.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
28 Jan 2020 00:43
#818072
Is the GS swingarm longer than stock? Does it allow for a wider tire?
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
