Handle bar controls
  • Bowserpup32
  • Bowserpup32's Avatar Topic Author
Handle bar controls
19 Jan 2020 06:38
#817418
What’s up guys!!! Trying to upgrade my hand controls on 78 kz1000a2. Currently running dual calipers in front. I’m not a fan of the stock levers and master cylinder. Currently have the trapezoid model. I was wondering if anyone could recommend a good aftermarket set of controllers for 7/8 bars that would work with existing cables, brakes, hoses etc.
Looking to spend roughly $300 if possible. Would need to be black. I have attached a photo of the style I’m looking for. Not stuck particularly to anything but certainly looking for newer style. Even something similar to what their running on newer sport bikes would be awesome. Just didn’t know if possible. Looking for some help here.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Handle bar controls
19 Jan 2020 12:46
#817458
Your picture is showing Milwaukee iron HD clutch and MC leveler that need a 1" OD steering bar.
Try search evil bay for 22 mm steering bar MC/clutch like Honda double disk bikes.
  • Bowserpup32
20 Jan 2020 16:55
#817508
Everything I’m finding under that search brings up some POS $25 to $40 set. I would have to assume their all crap for that price. Does anyone know of a particular brand and model that would work well for dual calipers in front. Looking for both left mechanical clutch and right brake with master. I would like to use original brake hoses as well.
  • martin_csr
  • martin_csr's Avatar
21 Jan 2020 07:59 - 21 Jan 2020 09:04
#817549
You can probably install the Fr brake master cylinder from a modern motorcycle having dual disks & 16mm mc piston bore (or 5/8") & you might be able to use the matching clutch lever & perch from whatever model the mc is from. Note: some don't have the mirror orifices.
I have a single disk front brake & installed the mc from a 2014 Honda CBR500 w 12.5mm bore. I got the Fr brake light wire assy from a 1000P police bike as it matched the stock wiring & was easier than fabbing something.
... Single disk Fr Br mc. HondaCBR500R.
Last edit: 21 Jan 2020 09:04 by martin_csr.
  • gordone
  • gordone's Avatar
21 Jan 2020 13:37
#817560
No eBay APP ID and/or Cert ID defined in Kunena configurationI have used a set of these for 3-4 years and are really happy.
Project:
  • DoctoRot
  • DoctoRot's Avatar
21 Jan 2020 15:42 - 21 Jan 2020 15:44
#817565
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationIf you want something nice, get a Brembo 16mm master with matching Domino clutch. its what I run on both my custom KZs. If you don't like the integrated reservoir they offer a remote reservoir as well.
Last edit: 21 Jan 2020 15:44 by DoctoRot.
  • gordone
  • gordone's Avatar
22 Jan 2020 01:59
#817595
DoctoRot wrote: If you want something nice, get a Brembo 16mm master with matching Domino clutch. its what I run on both my custom KZs. If you don't like the integrated reservoir they offer a remote reservoir as well.
What is the improvment with these?
Will you have better handling / braking feeling with these compare to the one I posted?
Project:
  • DoctoRot
  • DoctoRot's Avatar
22 Jan 2020 11:35
#817616
I've used those cheap Chinese Mc's as well. they work fine, but both I have owned had a slow leak at the cap and the paint quality is not good, the paint pealed off after a year of leaking brake fluid.
Brembo makes very high quality parts, with excellent QC, superior fit and finish, their master cylinders are anodized which has better longevity than paint. and is impervious to brake fluid.
performance wise they will be about the same.
The following user(s) said Thank You: martin_csr
  • Skidmark
  • Skidmark's Avatar
22 Jan 2020 12:31
#817624
Sometimes it's the finer details that make for good quality. And as always, you get what you pay for (and you pay for what you get!).
Retired gearhead
'81 KZ-750 E2
  • gordone
  • gordone's Avatar
22 Jan 2020 23:48
#817656
Thank you for replay,I have been lucky since I don’t have had leaks yet then.
Have noted the Brambo down, will properly by them in the future :)
Project:
