Gpz750 1982 will be a Eddie Lawson replica. Almost :-)
- foxkawa
14 Jan 2020 16:22 - 14 Jan 2020 18:30
Hi!
My name is Jan and i live in Sweden.
In november i bought mysel a Gpz750 1982 who had seen his best days.
I started the same day to take the Bike apart , most of the parts was junk but that doesn´t bother me becuase i should only use the frame engine and the electrical wiring..
First of all i bought a fork and a swingarm complete with rims from an zrx1100.
The fork was just bolton.
The swingarm i had to shave of 5mm and i also made som adapters so i could use smaller bearings so the oem swingarm bolt fit.
Bought a 3/8" offset front sprocket and shaved off the wheel hub 9mm so the sprockets got in line.
Last edit: 14 Jan 2020 18:30 by Street Fighter LTD.
Re: Gpz750 1982 will be a Eddie Lawson replica. Almost :-)
14 Jan 2020 18:32
Welcome to KZRider
I fixed your pictures so all can see them easily
Next time hit the insert all tab and your pictures will be full size
The following user(s) said Thank You: foxkawa
- Skidmark
14 Jan 2020 18:52
Welcome, Jan! Looking forward to seeing your progress with your bike. I am building a KZ750 with similar colors to the ELR, but more of a race flavor resto-mod.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- scubaanders
14 Jan 2020 21:17
Nice to see that you are making progress Jan. Nice that you was able to score a ZRX swingarm, pls post more pix.
/Anders
/Anders
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
- foxkawa
15 Jan 2020 02:34 - 15 Jan 2020 07:27
First of all i strippe,d the whole bike and sanded it, and then i cut away all brackets on the subframe that shouldn´t be in use. Painted the frame and engine in gloss black.
The best thing with this bike was that the engine was renovated but the rest of it was crap.
I don´t have any pics of this.
The zrx swingarm i got from crooober for a cheap price, thr fork from germany and the wheels i bought here in Sweden.
Attachment not found
Last edit: 15 Jan 2020 07:27 by foxkawa.
- foxkawa
15 Jan 2020 02:38Please Log in or Create an account to join the conversation.
- foxkawa
15 Jan 2020 02:40Please Log in or Create an account to join the conversation.
- foxkawa
15 Jan 2020 02:46
I find this speedo on ebay. It has digital showing on speedo but with speedocable, pretty easy to install except for the wiring diagram who was in chinese. But when i got it translate it was plug and play
- foxkawa
15 Jan 2020 07:34 - 15 Jan 2020 07:47
The handcontrols from zrx1100 is almost bolt on. You just need to change places of the cables in the connectors then it all work fine. It is twenty years between the controls but the cables has the same colour in the controls.
I also bought a little rear view camera and a monitor, just for show but it works fine.
Last edit: 15 Jan 2020 07:47 by foxkawa.
- foxkawa
15 Jan 2020 07:41
With the zrx swingarm the suspension will be wider then stock so i. The new shocks had 14mm ID had two bobbins for the swingarm and drilled a larger hole so it fits the upper shock bracket. The new shocks has 14mm bushings so i took a tube who had m10x1.25 inside . I turned off the outer diam from 20mm to 14mm except for 3mm . Now i have a nut that fits perfect in the upper hole on the shock.
Sorry for my english
- DoctoRot
15 Jan 2020 07:42
you got my attention! cool project.
- foxkawa
15 Jan 2020 07:43Please Log in or Create an account to join the conversation.
