Z/KZ 1000 mk 3
  • deano68
  • deano68's Avatar Topic Author
Z/KZ 1000 mk 3
30 Sep 2019 14:47
#811537
hello after posting about ST fuel tank fitting to CSR frame i thought id better put a post in the projects section about my alleged cunning plan! the bike was purchased via ebay a couple of weeks ago along with the 1000 LTD in the back ground it has been of the road since 1995 but seems to have been kept dry ish. the rats and mice have had a good chew on the wiring and the airbox but other than that its not too bad, the engine turns at least! the plan is to make a MK 3 Z1000 thingy . the running gear will be KZ1000 P, wheels , clocks etc. maybe some rearsets to get rid of the horrid standard foot peg mounts. the plan is to use as much kawasaki bits as possible. first pic shows bike as advertised. some body spent a lot of time making parts from stainless including the side panels!!!! the sissy bar and seat have gone in the skip as have the bars and highway pegs. heres some pics
76 KZ 400
78 KZ 650
82 Z 750(4)
80 KZ1000 ltd project
82 CSR 1000 work in progress
  • deano68
Re: Z/KZ 1000 mk 3
30 Sep 2019 14:52
#811538
tank fitted without too many issues. coil bracket had to be cut and bent and bit of hammer work on the inside to clear the frame rails. i need to fab up a rear tank mount and redo the front rubber mounts. the fork legs clear by about 6mm, so only just
76 KZ 400
78 KZ 650
82 Z 750(4)
  • deano68
Re: Z/KZ 1000 mk 3
30 Sep 2019 15:06
#811539
hopefully a better pic this time i had a read of how to post a picture!!
76 KZ 400
78 KZ 650
82 Z 750(4)
  • deano68
Re: Z/KZ 1000 mk 3
06 Oct 2019 08:23
#811919
busy weekend getting the rear end back together after a PO cut it off. im sure the handling was great due to the lack of shock brace! work supplied a table for the frame tubing which was the perfect size inside and out,two chair legs for the seat riser tubing and a KZ 400 frame gave up the brace and inner rear mudguard
76 KZ 400
78 KZ 650
82 Z 750(4)
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: Z/KZ 1000 mk 3
10 Oct 2019 14:10
#812192
interesting project keep us posted.
  • deano68
Re: Z/KZ 1000 mk 3
11 Oct 2019 08:48
#812249
thanks, i was beginning to think it wasnt!!! more updates to come ive been a busy boy
76 KZ 400
78 KZ 650
82 Z 750(4)
  • deano68
Re: Z/KZ 1000 mk 3
17 Oct 2019 07:47
#812585
new fuse box fitted and moved up to make things a bit easier
76 KZ 400
78 KZ 650
82 Z 750(4)
  • deano68
Re: Z/KZ 1000 mk 3
17 Oct 2019 07:51
#812587
only a bit more spagetti to sort out !! newish switches on the way from an ER6 . two relays to wire in for the high/low lighting i should be able to use a larger bulb for the lights
76 KZ 400
78 KZ 650
82 Z 750(4)
  • deano68
Re: Z/KZ 1000 mk 3
26 Oct 2019 11:31
#813070
electrics finished, got rid of safety devices and light bulb fail unit thing. two relays added for high/low beam it even got hazzard light which is new for me on a motorbike. swiches are from ER 650 luckily it seems kawasaki havnt changed wire colours so they were not too bad to wire
76 KZ 400
78 KZ 650
82 Z 750(4)
  • perrykz1000
  • perrykz1000's Avatar
  • Have a safe day !!
Re: Z/KZ 1000 mk 3
26 Oct 2019 11:49
#813071
Great work. I used the ATC type fuses too. Much , much better system.
  • DoctoRot
  • DoctoRot's Avatar
Re: Z/KZ 1000 mk 3
26 Oct 2019 12:16
#813074
already so much better. Im not a fan of the CSR styling personally. keep on keeping on.
  • deano68
Re: Z/KZ 1000 mk 3
02 Nov 2019 11:10
#813446
tank fitted without too much trouble and works with the CSR forks and triples and also KZ 1000p forks and triples. a bit of bashing on the inside to clear frame rail at the rear im going to be using the standard airbox so had to make something up for the rear that could unbolt
76 KZ 400
78 KZ 650
82 Z 750(4)
