89 KZ1000P bobber?
- jimdgreat1
Re: 89 KZ1000P bobber?
30 Aug 2019 11:51
Smart man! Switching to a 530 chain would be wise.
I stayed with the original gear ratio and 630 chain. It will probably out last me.
30 Aug 2019 13:07jimdgreat1 wrote:baldy110 wrote: What did you attach the upper strap mount to?
There is a threaded bung welded to the frame there. Don't know what it was for originally. There is one on both sides. Look like they could be foot peg mounts that were added at some point.
For the side box crash bars.
- jimdgreat1
30 Aug 2019 15:10
Holy !as! That front nut is on there! Going to have to get out the impact.
30 Aug 2019 15:18
They have to be tight. Might try some heat in case the OP used red Loctite.
- ThatGPzGuy
30 Aug 2019 18:01
Looks like they cut off the loop for the rear exhaust mount and the side bags. Too bad but if you are not going to use bags then probably not a big loss.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- jimdgreat1
11 Sep 2019 17:43
I'm still trying to get the front sprocket nut off. Bought and used a Dewalt impact with 600 pounds torque. Still on there. I'm still thinking this was on from the factory. The tabs were bent over the nut very uniformly and equal on both sides.
Will I have to cut this off? I don't have my torch here. Guess I could get a cheap LP hand torch and try a little heat.
- old_kaw
12 Sep 2019 07:15 - 12 Sep 2019 07:20
You can run a bolt / nut (or two bolts) through the chain behind the swingarm pivot and use a cheater bar on a breaker bar. Some heat might help, but I wouldn't get it too hot, since the rubber output shaft seal is right behind the sprocket.
It looks like someone cut the left muffler hanger bracket off of the frame while doing "improvements" to the bike. What the hell do the japs know anyway? it's gotta go! LOL
Attachment not found
1981 Kawasaki Kz1000K1
Last edit: 12 Sep 2019 07:20 by old_kaw. Reason: hmmmmm
- jimdgreat1
12 Sep 2019 07:30
Yeah I don't think I should get it too hot.
Have tried a 4 foot cheater bar and this impact and holding the rear brake. It's not moving but the chain could be stretching limiting the effectiveness of the impact.
- old_kaw
12 Sep 2019 07:35 - 12 Sep 2019 07:39jimdgreat1 wrote: Yeah I don't think I should get it too hot.
The brake isn't enough if it's that tight. You need to bolt that sucker SOLID, then try your cheater bar. The likelihood of that 630 chain stretching is slim to NONE. The brake isn't holding it. Also, be careful not to round off the nut and use a tight fitting socket. You could also try a sharp chisel to split the nut away from the shaft, but that is a last resort type of move.
Last edit: 12 Sep 2019 07:39 by old_kaw.
- baldy110
12 Sep 2019 09:18
Are you using a cordless impact or air? Those cordless ones won't work no matter what the manufacturer rates it's torque value at. Use a 1/2" air impact gun, it'll zip it off like it wasn't tight.
- old_kaw
12 Sep 2019 10:09 - 12 Sep 2019 10:11baldy110 wrote: Are you using a cordless impact or air? Those cordless ones won't work no matter what the manufacturer rates it's torque value at. Use a 1/2" air impact gun, it'll zip it off like it wasn't tight.
Not always the case> I have a craftsman 1/2" air impact that quite often I have to break lug nuts loose on my truck before it will budge them. (they are not even close to being stuck hard) It also depends if my compressor is fully pumped up to the 130 PSI it is set at, or if it is just at the tip-in point to recharge.
PLUS, using the brake to hold the sprocket while loosening will act as a damper to the impact blows and hinder removal of an extremely troublesome fastener. A couple of long 1/4" or 5/16" bolts through the chain links will hold the sprocket solid.
Here is a neato tool to hold the sprocket while loosening the nut. Not necessary with a few bolts.
Last edit: 12 Sep 2019 10:11 by old_kaw.
12 Sep 2019 11:53
The following user(s) said Thank You: Scirocco, old_kaw
