First car, (bike) wash in over 20 years ...
  • urankjj
  • urankjj's Avatar Topic Author
29 Jun 2019 17:10 - 29 Jun 2019 17:16
#806689
From my storage unit cleanout post. Just got the time today to give her a good wash since before she went into storage, (20 + yr's ago). Sprayed it down back then with a lot of 'corrosion protectant', and it seemed to have payed off . Now I need to get her runnin….
Last edit: 29 Jun 2019 17:16 by urankjj.
  • urankjj
Re: First car, (bike) wash in over 20 years ...
29 Jun 2019 17:14 - 29 Jun 2019 17:20
#806690
the other pic.
Last edit: 29 Jun 2019 17:20 by urankjj.
  • Oldjeep
  • Oldjeep's Avatar
29 Jun 2019 17:46
#806692
Looks great. Love the color. 99% or the old bikes I see around here are black.
Chuck
81 KZ750 LTD
03 FZ1
www.oldjeep.com
The following user(s) said Thank You: urankjj
  • SWest
  • SWest's Avatar
  • 10 22 2014
29 Jun 2019 19:04
#806693
NICE B)
  • urankjj
04 Jul 2019 19:14
#806975
I figured I would try to start her up today for some 4th of July fireworks. I first sea-foamed the carbs completely while still on the motor, let them sit for 2 days, then drained the float bowls, (a lot of crud). Cleaned up and freed the Pingle petcock valve that had been in the off position for some 20 yr's. That's about all I did. This is a 1327cc motor and it is only kick-start as the way it was built. With a fresh battery hooked up I put my right leg to work. If not very careful, the kick lever will come back up and hurt you. It did start up after several kicks and stayed running for about 10 seconds. I think I should have drained the race fuel that had been in the tank but I hadn't. Will try again this weekend and try to include a video and pics.
  • baldy110
  • baldy110's Avatar
05 Jul 2019 09:27 - 05 Jul 2019 09:29
#807003
Nics!! Ill be the first to say this, You ought to be ashamed of yourself for leaving that nice of a bike in a shed and not riding it!!
Last edit: 05 Jul 2019 09:29 by baldy110.
  • urankjj
05 Jul 2019 18:37
#807025
Yep, I know it, but sometimes that's what life can do to ya, (keep you off the track and in the pit's) if you know what I mean. Anyway, I could not fire the bike back up today, and believe me I tried. The arch in my right foot is at least 1" higher from kicking the hell out of her. I think it's carb related as I did not remove them for a proper disassembly and cleaning. The #1 carb floods fuel as soon as I turn on the petcock and try to start up. Stay tuned for more.....: )
  • urankjj
06 Jul 2019 17:40
#807089
Still cleaning the corrosion protectant off that I used liberally before storage. "Sometimes it's what's under the seat that counts".....
  • SWest
  • SWest's Avatar
  • 10 22 2014
06 Jul 2019 18:42
#807095
New battery?
  • urankjj
07 Jul 2019 04:59
#807106
That is a new battery but not the correct one,(does not fit in battery box). I just J-rigged that one in there so that I could try to start the motor. I had a Novella dry cell battery in there from 20+ yr's ago that had seen better days.
