83 KZ1100ltd Rebuild
- CCrosswait
18 Jan 2019 11:11
After flipping a KZ1000 Police bike and gifting a 77 RD400 to my father in law, I had this big gaping hole in my garage that I needed to fill. So it worked out great that Rich was looking to part with his 83 KZ1100ltd.
Drove a good 2-3 hours to pick up the bike along with a mountain of parts, Vetter fairings, and hard bags. Somehow, with the help of Rich and his son, we got the bike and all the parts into the truck. Everything rode well enough back home and now there be no more hole in the garage. Problem solved!
Looking to keep this one close to stock and just give it a complete refresh: powder coat the frame, new bearings all around, rebuild the forks, master cylinders, etc... This is my first full teardown and rebuild but I'm confident I won't screw things up too bad!
2019 Indian FTR1200S
2018 Triumph Rocket 3
1981 Kawasaki KZ1100A1
1977 Yamaha RD400
1980 Honda Express II
1977 Yamaha RD400
- CCrosswait
Re: 83 KZ1100ltd Rebuild
18 Jan 2019 11:42
Pulling everything off frame was straightforward enough, except for the swing arm bushings. The service manual's instructions to thread a bolt into the bushing and pull were not effective so I must turn to the collective wisdom of the internet to provide inspiration on how to solve my problem.
Most of the solutions I found involved fastening some manner of a slide hammer and pounding the bushings out. Folks mostly seemed to have used vise grips to build a slide hammer or drilled and tapped the bushing to match a slide hammer they already possessed.
Having reviewed other's solutions to my problem, I needed to identify a course of action which was both expedient and (more importantly) cheap. Time to soak the bushings in liquid wrench while I ponder.
Since I do not posses a slide hammer and am not fond of drilling out the bushing to 5/8-18 to accommodate a rental slide hammer, I decided I shall fashion one myself. Seems simple enough, a slide hammer consists of a threaded rod, a large mass, and a stopper.
Voila!
A few bucks of hardware later I have my slide hammer and am feeling pretty proud of myself. A M5x0.8 threaded rod, the heaviest impact socket I've got, a couple washers and a flanged nut.
After applying some heat to the frame around the bushing and a far bit of persistence, this setup actually worked. But only on one side. The right side bushing was more stubborn and required a different solution.
Inspiration struck and I rotated the impact socket around and used the tool like a flywheel puller, tightening the nut with an 8mm wrench.
The little threaded rod held up and the bushing finally came out.
Time for a celebratory beer!
Voila!
1977 Yamaha RD400
1977 Yamaha RD400
18 Jan 2019 13:03
Well done CCrosswait, self made tools are the best and cheap solution if you have the brain to construct them by your self.
- daveo
Nasty job, but somebody's got to do it at least once in half a century.
Did the swing arm maintenance on my 1100 way back in 2010.
:evil:
1982 KZ1100-A2 bike
1984 ZN/ZX1100 motor
- M_a_t_t
21 Jan 2019 19:05
Gonna watch this thread closely. I'm hoping to strip my bike (83 KZ1100A) down and rebuild it soon, or atleast get some systems rebuilt.
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
- Rich
23 Jan 2019 07:46
Craig, I'm glad it found a good home and that you're finding it rewarding. I'll look in now and again to watch the progress. Should make for a good bike for the right guy.
For anybody who's interested, Craig is a very stand up guy, I was pleased to make his acquaintance.
- CCrosswait
24 Jan 2019 17:33Rich wrote: For anybody who's interested, Craig is a very stand up guy, I was pleased to make his acquaintance.
Well thanks for saying so Rich. :blush:
1977 Yamaha RD400
1977 Yamaha RD400
- CCrosswait
25 Jan 2019 16:25
Seeking advice.
Getting the frame and other bits ready to get media blasted and powder coated. Along with the frame I plan on having the motor mounts (front and rear) top triple clamp, swing arm and support bar, battery box, center and side stands, and the swing arm bushing cover plates.
Anyone see any red flags or omitted parts in the above list?
1977 Yamaha RD400
1977 Yamaha RD400
- M_a_t_t
25 Jan 2019 18:37
Calipers? What about the piece that the pegs attach to?
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
17 Versys X 300 abs
81 kz650h1
81 kz750e2
- CCrosswait
26 Jan 2019 06:02M_a_t_t wrote: Calipers? What about the piece that the pegs attach to?
Calipers are a good call. Is powder coat appropriate for brake fluid or do they need special paint?
The foot peg mount is mostly bare metal and I think I'm going to keep it original.
1977 Yamaha RD400
1977 Yamaha RD400
- M_a_t_t
26 Jan 2019 12:33 - 26 Jan 2019 12:38
Powder coat is supposed to be chemical resistant. I don't think I've read anything about brake fluid specifically though. Just to be clear you don't want to powdercoat the inside of the caliper, just the outside. I have some powdercoated sockets I made I can try one in some brake fluid if you would like. I used Harbor freight powder though so not as good as a "professional" powder probably.
What about the kawasaki logo/bracket in the front on the forks? You can do a two tone powdercoat or just black and sand the letters down.
And the lower half of the forks?
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
17 Versys X 300 abs
81 kz650h1
81 kz750e2
Last edit: 26 Jan 2019 12:38 by M_a_t_t.
- CCrosswait
27 Jan 2019 17:12M_a_t_t wrote: Just to be clear you don't want to powdercoat the inside of the caliper, just the outside. I have some powdercoated sockets I made I can try one in some brake fluid if you would like.
Yes, it was understood that the internal bore of the calipers would be masked.
If you are willing to run an experiment on your powder coated sockets then I would be interested in the results. Not sure of the best way to expose the sockets. You think just soak one for a couple days?
1977 Yamaha RD400
1977 Yamaha RD400
