77 kz1k restomod
  • jowek70
  • jowek70's Avatar Topic Author
Re: 77 kz1k restomod
17 Jan 2022 09:49
#860623
I thought i updated this awhile ago but here is the last pic before it got delivered to Ohio for dads 60th birthday in 2020...
Brought my dad to to tears!
  • Mikaw
  • Mikaw's Avatar
17 Jan 2022 11:02
#860624
I can see why. It’s a jewel to keep in the family. Great job!
The following user(s) said Thank You: jowek70
  • jowek70
05 Nov 2025 08:56
#918732
Bikes on its 5th summer of riding around.  Have an oil leak to chase on the left side of the engine, not sure if its the base gasket or the valve cover; hard to tell when oil blows all over when riding.  Going to pull the engine over Thanksgiving weekend and see what i can determine.  Last time i thought i remember a slight crack in the valve cover that i tried RTV but possibly opened back up.  Not sure how easily it can be repaired or replaced, if anybody has a chrome valve cover in good shape they'd like to let go of.
  • TexasKZ
  • TexasKZ's Avatar
05 Nov 2025 14:41
#918744
Might be the tachometer drive.
  • jowek70
06 Nov 2025 04:30
#918764
It seems too far to the left side for the tach drive to be the source.  The oil pools right above the stator cover at the base gasket.  I will add that to the list of possible sources though.
  • jowek70
10 Nov 2025 08:16
#918935
Got a chance to look over the bike this past weekend; the base gasket is not the culprit as the oil is running down the cylinders.  The valve cover is cracked on that side and as mentioned by  TexasKZ , the tach cable does have a small leak. Going to replace the valve cover, valve cover gasket and the tach cable seals/gaskets.
  • TexasKZ
  • TexasKZ's Avatar
10 Nov 2025 15:15
#918945
Keep in mind that the tach drive has a gasket, oil seal and an oring.
www.partzilla.com/catalog/kawasaki/motor...over-77-78-a1-a2-a2a
  • jowek70
11 Nov 2025 04:09
#918954
right, already added the parts to my cart.
