The Texas Turd
  • Dr. Gamma
  • Dr. Gamma's Avatar
Re: The Texas Turd
03 Dec 2017 12:00
#775482
Do I see big pieces of red silicone on the pickup screen???? I always get a big chuckle when I see red or blue silicone oozing from every joint on a KZ motor. Reminds me on being back in Chicago. Certain folks in Chicago must have bought red or blue silicone by the 5 gallon bucket. I have seen pickup screens COMPLETELY blocked with pieces of silicone!!! I had one motor that the owner used so much silicone on the head gasket that it blocked the oil flow to one side of the head!!!!!
1986 RG500G 2 stroke terror.
  • GregZ
  • GregZ's Avatar Topic Author
Re: The Texas Turd
11 Dec 2017 17:36
#775856
There will be no silicone used when the engine goes back together, and yes the inside was full of it.
I have never tig welded but I gave it my best shot on the frame ( with a little help from my pipefitter buddy lol) . I might have to tweek a little on the seat latch mount bracket , however the front frame section came out pretty good.
  • GregZ
Re: The Texas Turd
11 Dec 2017 17:36
#775857
  • GregZ
Re: The Texas Turd
11 Jan 2018 17:16
#777214
It's looking better. A few more minor things and the engine will be done . Nothing was reused from the texas turd engine except the cases. New used crank, block stock bore pistons new rings. New used head, new valves , guides and seals. New used clutch basket and brand new clutch plates. trans thoroughly inspected and near perfect shift forks. New cam chain and rollers and gromets An incredible rebuild
  • ajsfirehawk
  • ajsfirehawk's Avatar
Re: The Texas Turd
13 Jan 2018 17:16
#777261
Clearly a labor of love Greg. The has to be as close to a boat anchor as you could save. A beautiful piece of work.
79 KZ650 SR
80 KZ1000 Z1 Classic
83 KZ1100 LTD
Z900RS
23 Mach 1
  • Bozo
  • Bozo's Avatar
  • Ride it like u stole it
Re: The Texas Turd
14 Jan 2018 18:02 - 14 Jan 2018 18:06
#777281
GregZ wrote: This by far is the biggest piece of chit I ever seen. I knew it the day it showed up on the trailer, I knew then to cut my loss and sell, let some other idiot restore. But I'm a dumb ass so I'll give it my best.
There is nothing good on the bike. I'm starting with a frame and top engine case. The crank is junk , trans is junk and I'm hoping my buddy can repair the lower case, it;s cracked and and one of the mount lugs for the point housing is busted off. the timing chain guide was broke off, in two pieces caught in the crank etc.
look at this crap
Is that the remains of their pet frog that went missing 5 years ago (on the oil pump mesh). Sorry about the late entry I just saw this thread, its great to see that you are going ahead with this build.
Last edit: 14 Jan 2018 18:06 by Bozo.
  • Ed_in_Miami
  • Ed_in_Miami's Avatar
Re: The Texas Turd
25 Jan 2018 13:53
#777764
Very cool project.
YES!!!! Turds can be polished!!
This is my build:
kzrider.com/forum/11-projects/600312-ano...rtment-build?start=0
There are many more like it, but this one is mine... news to come!
  • BlackZ1R
  • BlackZ1R's Avatar
  • Kawasaki in my blood
Re: The Texas Turd
27 Jan 2018 13:05
#777868
GregZ wrote: It's looking better. A few more minor things and the engine will be done . Nothing was reused from the texas turd engine except the cases. New used crank, block stock bore pistons new rings. New used head, new valves , guides and seals. New used clutch basket and brand new clutch plates. trans thoroughly inspected and near perfect shift forks. New cam chain and rollers and gromets An incredible rebuild
Nice work! What did you spray the engine with?
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
  • GregZ
Re: The Texas Turd
25 Feb 2018 17:58 - 25 Feb 2018 17:59
#779356
I used PJ1 fast black
Last edit: 25 Feb 2018 17:59 by GregZ.
  • GregZ
Re: The Texas Turd
25 Feb 2018 18:05 - 25 Feb 2018 18:08
#779357
Today I was going to drop off the frame to get media blasted, figured with all the repairs that were needed i'd give it one more look see inspection. I chased out all the threads and found a broke bolt in the tail section mount. How the hell does someone break off a bolt here wtf ? So instead of proper repair the idiot PO drilled and tapped a new hole.
Fixed Texas style
Last edit: 25 Feb 2018 18:08 by GregZ.
  • GregZ
Re: The Texas Turd
25 Feb 2018 18:11 - 25 Feb 2018 18:13
#779358
I'll have to cut that piece off and remove the hacked up nut and tack on new nut or try to drill and heli coil it if possible. This bike is starting to be a headache
Last edit: 25 Feb 2018 18:13 by GregZ.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
Re: The Texas Turd
25 Feb 2018 18:33 - 25 Feb 2018 18:41
#779362
Sorry, but a broken M6 screw should be an easy out for you (me) with the right tools!!!
Make a center punch and use a counter clockwise drill 4mm.
Last edit: 25 Feb 2018 18:41 by Scirocco.
