Almost there.
- McZed
Almost there.
29 Dec 2016 07:03
I’ve put about 50 miles on it so far and it seems to be running ok but there are still a few little things I will have to do. The starter motor seems to turn over a bit slow; I’m hoping it’s just dirty contacts. It could also do with a new set of plug leads, and a new set of tyres wouldn’t go amiss. The front suspension doesn’t seem to have much travel so I will have to check that out, but all things considered it’s turned out pretty well.
Cosmetically I’m not going to do anything; I prefer it to be in as near original condition as possible, this is going to be a bike for riding so I don’t want to get to precious with it. Any advice on the slow starter and front suspension would be appreciated. I have taken a few photos of it alongside my other two bikes; do you think I might have Kawasaki disease?
Attachment IMG_2230.JPG not found
Attachment IMG_2236.JPG not found
Attachment IMG_2232.JPG not found
Attachment IMG_2235.JPG not found
Re: Almost there.
29 Dec 2016 07:13 - 29 Dec 2016 07:14
KZ problem? I don't see a problem here... :evil:
Fork? Someone could have put some different springs in there. Or used motor oil instead of the proper fork oil. Sounds like time for a good servicing. Then you will know what if anything needs to be done.
Cleaning the contacts and making sure you have a strong battery is the correct first step towards working out the slow starter. Next would be to take apart the starter to see if anything is amiss. Good luck. It shouldn't be overly difficult to figure out.
Last edit: 29 Dec 2016 07:14 by Nessism.
- Tyrell Corp
Re: Almost there.
29 Dec 2016 08:27
Cleaning the contacts and making sure you have a strong battery is the correct first step towards working...
Yes, do both the Battery + to solenoid to starter
then do the Battery - to frame earth,
Old battery cables can corrode from the inside out.
kz1300
definitely one for the 'total headbangers' specialist category.
kz1300
Re: Almost there.
29 Dec 2016 11:58
Could be worn bushings if all else looks good.
- tfh903
Re: Almost there.
31 Dec 2016 09:59
I know this sounds crazy but... had a slow starter, tried and checked everything, replaced battery cables, added extra ground to starter, redid ground at engine ,, no help. then I swapped the battery and starter leads on the solenoid and the slow starter went away. spins faster now no problem. I realize that relays usually don't care which way the voltage is flowing, but in my case it did. easy to check.
