1980 KZ200 Street Tracker/Scrambler
- BrianF
31 Oct 2016 11:38
Just finished my first project bike at 61, only got back into bikes 10 months ago after a break of 40 years. I picked up this Z200 by chance, ii had only covered 3440 miles with 1 owner and had been in storage since December 1980. I was originally going to restore it to stock but when I worked out how much it was going to cost I decided to do something a bit different with it.
Here are some before during and after pictures.
Attachment Rebuild5.jpg not found
Attachment Rebuild4.jpg not found
Attachment Rebuild3.jpg not found
Attachment Rebuild2.jpg not found
Attachment Rebuild1.jpg not found
Attachment rebuild6.jpg not found
Attachment Rebuild7.jpg not found
Attachment Z200FB.jpg not found
Attachment Z200FB2.jpg not found
Attachment FB3.jpg not found
Attachment FB4.jpg not found
Attachment FB5.jpg not found
Attachment FB6.jpg not found
Attachment FB7.jpg not found
- GPzMOD750
Re: 1980 KZ200 Street Tracker/Scrambler
31 Oct 2016 11:45
Sweet little thumper. Welcome to the madness!
The following user(s) said Thank You: BrianF
31 Oct 2016 17:12 - 31 Oct 2016 17:13
Very nice. How does it run? Is there enough clearance between the rear tire and its fender for full suspension travel?
Last edit: 31 Oct 2016 17:13 by TexasKZ.
- diggerdanh
- BrianF
01 Nov 2016 06:07TexasKZ wrote: Very nice. How does it run? Is there enough clearance between the rear tire and its fender for full suspension travel?
Had some trouble getting the jetting right but it's running well now. There's plenty of suspension travel clearance for me but I'm pretty light. There's not much clearance at the front edge of the swing arm, had to go down 1 tooth on the front sprocket and fit a longer chain to get the wheel as far back in the chain adjusters as possible.
- KZ802
01 Nov 2016 06:40
wow that thing came out awesome! love the seat and the color scheme. Great job
1980 KZ750 LTDx2
1978 KZ1000 LTD
1976 KZ900 A
1978 KZ1000 LTD
1976 KZ900 A
- missionkz
01 Nov 2016 18:54
Lol.
Different strokes for different folks.
I would have made it stock and kept it a pretty bike.
Instead its .... well, iI'll be the one to take the hit.
Yuk, it does nothing for me.
Ha ha.
Ha ha.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- larriken
02 Nov 2016 00:28
Very cool bike you have made there. Love the knobblies!
- Kidkawie
- I bleed premix
02 Nov 2016 07:00BrianF wrote:TexasKZ wrote: Very nice. How does it run? Is there enough clearance between the rear tire and its fender for full suspension travel?
What was the issue with the chain? Having been around/modified some vintage MX bikes whenever you add more rear suspension travel you usually need to add slack to the chain and fab up some sort of chain guide/roller system. Here's one I made up for a 76 KX125 after adding 1" of travel. With the bike on a stand and the shocks removed you need to operate the swingarm to find the point where the chain is tightest. Hold the wheel at that position and adjust the chain so there's a little slack. Reinstall the shocks and see where you're at. You may get away with just a roller or two or need a guide and slider as well.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- LesbianSeagull
- Here to end my reverse Midas touch curse
02 Nov 2016 09:27
This is cool as hell! Love the scrambler look.
Some days you're the windshield. Some days, you're the bug
- BrianF
02 Nov 2016 11:08Kidkawie wrote:BrianF wrote:TexasKZ wrote: Very nice. How does it run? Is there enough clearance between the rear tire and its fender for full suspension travel?
I just needed to get the rear wheel as far back as possible to allow the oversize tyre to clear the swingarm. I also shaved a bit off the side of the rear tyre by putting the bike in first gear at fast idle on a paddock stand then held a surform wood rasp on the edge of the tyre.
