KZ550 Cafe Retromod
- acetone
11 Jun 2016 12:08 - 11 Jun 2016 12:23 #730967
by acetone
KZ550 Cafe Retromod was created by acetone
I thought I'd post my project bike. My KZ550 is an 81 that I took down to the frame. If I could figure out how not to post upside down photos, that would be a plus.
Attachment IMG_5738-2-3-4-2.JPG not found
Last edit: 11 Jun 2016 12:23 by acetone.
- GPzMOD750
- Thank you received: 148
11 Jun 2016 16:17 #730988
by GPzMOD750
Replied by GPzMOD750 on topic KZ550 Cafe Retromod
Welcome.
Seems you figured it out.
- acetone
13 Jun 2016 06:03 - 13 Jun 2016 06:09 #731173
by acetone
Replied by acetone on topic KZ550 Cafe Retromod
Last edit: 13 Jun 2016 06:09 by acetone.
- acetone
13 Jun 2016 06:13 #731175
by acetone
- acetone
13 Jun 2016 06:16 #731176
by acetone
- acetone
13 Jun 2016 06:19 #731177
by acetone
- acetone
13 Jun 2016 06:24 #731178
by acetone
Now the really tricky part. I made the final carbon fiber part by vacuum resin infusion. I could not get the bag to seal after two days of trying. I didn't order enough .50 cent per yard vacuum bag (only got 1 yard) and finally I just said screw it and figured I'd see what would happen if I gave it a shot. The part infused PERFECTLY and the bag stayed sealed for 24 hours no problem. Definitely some kind of miracle.
- acetone
13 Jun 2016 06:31 #731180
by acetone
Here's the part as it came out of the mold. It weighed almost nothing at this point. What is great about the resin infusion process is it only allows enough resin into the part to saturate the cloth leaving you with the lightest and strongest part possible. The carbon pattern got a little tweaked on one side but the point of the bike isn't perfection. A perfect part would look funny on this bike when its done. The leather seat will cover the curved part of the carbon fiber.
- acetone
13 Jun 2016 06:37 #731182
by acetone
I then vacuum bagged some reinforcement layers on the inside. I used a coremat material and additional layers of carbon material. Two layers make up the surface then one layer of coremat where the seat will mount to the bike and where I will be sitting. Then I have a layer of heavy fiberglass material and then two more layers of 12oz carbon fiber. The part weighs maybe three pounds. I finish sanded it glass smooth and eventually it will be sprayed with a low gloss top coat.
- acetone
13 Jun 2016 06:46 #731183
by acetone
Now I move on to mounting it on the bike, when its done the seat will be trimmed quiet a bit, it still looks a little bulky right now. Part of the design of the seat is to allow a simple box tube hoop to help retie in the rear of the frame and serve as a support for the seat. I don't want any external fasteners showing through the shell of the seat and I am working on mounting it now. I think I will use an epoxy to mount steel angle stock with locator pins welded in. The seat will lock down using an electric door striker like the kind at the front door of an apartment building. They use a 12vdc actuator which will tie into the microcontroler I am using to run the bike.
- loudhvx
- Thank you received: 1616
13 Jun 2016 10:01 #731208
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic KZ550 Cafe Retromod
Wow, that is some amazing work!
1981 KZ550 D1 gpz.
Other links.
The following user(s) said Thank You: acetone
- punisher11b
- Thank you received: 22
13 Jun 2016 10:04 #731209
by punisher11b
