1976 Z750 twin
15 May 2017 12:11 #761984 by 650ed
Replied by 650ed on topic 1976 Z750 twin
Be SURE to use a new, correct lock washer on that engine sprocket so the problem never happens again. Ed
The following user(s) said Thank You: maxbond1995
02 Apr 2018 05:33 #781140 by maxbond1995
Replied by maxbond1995 on topic 1976 Z750 twin
Hi guys,
I have some troubles here....for some time I tried to figure out why my bike in running pretty well when the tank is full, and start to run on only 1 cyl when the tank is half full. Then I took apart petcock and installed new gas tubes and it worked fine. Yesterday I reset the ignition timing with strobe light. Today I went on a ride but the engine doesn't run well. It vibrates a lot and it doesn't have the right kick when I open the throttle. I wonder if there is maybe something about ignition timing...since the instruction manual was written 40 years ago and I suppose that gasoline back then was a bit different? Does octane rating affect ignition?
24 Dec 2018 09:31 - 24 Dec 2018 09:32 #795623 by maxbond1995
Hi guys, I think I found the problem. Today I removed needle jets and one is considerably more worn than another. How much play should the needle have in the jet? Should the needle completely close the needle and prevent flow of the gasoline?
Here’s a photo of needle inside the jet.
Last edit: 24 Dec 2018 09:32 by maxbond1995.
24 Dec 2018 09:33 - 24 Dec 2018 09:37 #795624 by maxbond1995
Last edit: 24 Dec 2018 09:37 by maxbond1995. Reason: No photo was attached
  • DoctoRot
26 Dec 2018 00:40 - 26 Dec 2018 00:41 #795683 by DoctoRot
Replied by DoctoRot on topic 1976 Z750 twin
if the needle jet or needle are worn they should be replaced. what state are the diaphragms in? Did you figure out your ignition problem? is your advancer rusty?
Last edit: 26 Dec 2018 00:41 by DoctoRot.
26 Dec 2018 15:42 #795719 by Nebr_Rex
Replied by Nebr_Rex on topic 1976 Z750 twin
Is that a pic of the needle and seat or the needle jet and jet needle?
Post a pic that is 90 degrees of the one you posted.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
27 Dec 2018 00:04 #795745 by maxbond1995
DoctoRot wrote: if the needle jet or needle are worn they should be replaced. what state are the diaphragms in? Did you figure out your ignition problem? is your advancer rusty?
Yes I know but I have problem finding the correct one (Z-4), but I do have machines to make new ones.
The diaphragms are in good shape, they are not torn or damaged.
The ignition works fine, breaker points and capacitor are new, advancer cleaned and lubricated.
27 Dec 2018 00:06 #795746 by maxbond1995
Here’s the pic (I hope it will upload from mobile phone...)
27 Dec 2018 14:01 - 27 Dec 2018 14:07 #795784 by missionkz
Replied by missionkz on topic Title replacement for a barn find.
That is the emulsion tube and jet needle. The tube looks worn, corroded and maybe the needle is worn too... I seems like it should be nearly perfectly round inside so the emulsion tube operates correctly at different manifold pressures and throttle settings.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 27 Dec 2018 14:07 by missionkz.
27 Dec 2018 19:34 #795809 by maxbond1995
Replied by maxbond1995 on topic Title replacement for a barn find.
Yes, the tube is in pretty bad shape and you can feel play of the needle inside. But does (when new) needle completely closes the hole in the tube and seals it?
  • DoctoRot
28 Dec 2018 03:17 - 28 Dec 2018 03:17 #795818 by DoctoRot
Replied by DoctoRot on topic Title replacement for a barn find.
is the internal bore of the needle jet worn? is the needle worn?
Last edit: 28 Dec 2018 03:17 by DoctoRot.
28 Dec 2018 03:46 #795819 by maxbond1995
The needles seem ok. I measured them, they are both 2.99 mm in diameter, the inside diamter of emulsion tubes is 3.15 mm, but since the inside micrometer has 3 spindles I can't measure roundness...
