decided to keep the 95 and see what I can do.
  • kaw-a-holic
  • kaw-a-holic's Avatar
Re: decided to keep the 95 and see what I can do.
23 Jan 2016 14:58
#707795
huntersdad14 wrote: I think it's original. What are you referring to fsm?. I did find that the exhaust can and intake cam were off 1 pin (43 instead of 44) so I corrected that. What I just now noticed is according to the clymer.when you set the cam alignment,you get 1 and 4 to tdc.which I've done, the "in"mark on the intake cam should be "a little above the rear surface of the cylinder head" but at top dead center I'm a little below. Thinking I'm off a few teeth on the crank?
Field
Service
Manual
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • huntersdad14
  • huntersdad14's Avatar Topic Author
Re: Re:decided to keep the 95 and see what I can do.
23 Jan 2016 14:58
#707796
Should go here?
Jeremy
  • huntersdad14
23 Jan 2016 15:08
#707798
Yes. According to the clymer the spec is 5.07 in between pin 1 and 21. From center of pin 1 to center of 21 I'm spot on
Jeremy
  • huntersdad14
23 Jan 2016 15:22
#707802
So what I'm thinking is,take 1 of the cams out, put the crank on top dead center and realign both cams
Jeremy
  • zukdave
  • zukdave's Avatar
23 Jan 2016 16:00 - 23 Jan 2016 16:01
#707804
I cut a spare cover for my ZX750A1 motor so I can check it with the top slider installed.
Also be able to degree them set up as it will be running.
[IMG
[IMG
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Last edit: 23 Jan 2016 16:01 by zukdave.
  • kaw-a-holic
23 Jan 2016 16:11
#707805
Unfortunately I am not familiar with J model heads.
Jon
1977 KZ1000a1
Mesa, AZ
  • huntersdad14
23 Jan 2016 16:23
#707807
It's gotten to too dark tonight to do much more so I'll get back to it first thing. Curious as to how it jumped so far. Was 1 tooth off on the cams and I'm guessing 2-3 on the bottom end. Looks like the PO has had the valve cover off cause some of the bolts were hand tight and weren't all the same.
Jeremy
  • Rockranch
  • Rockranch's Avatar
23 Jan 2016 22:58 - 23 Jan 2016 23:09
#707837
huntersdad14 wrote: Progress so far. Starter removed. The post on it is very lose and spinning. There's a blue wire with a red stripe that wasn't hooked up to anything (pic). Removed the valve cover and am inspecting the cam chain and cam shafts. I pulled the cap and spring for the cam chain tensioner and there wasn't much tension on it.
Need a starter? Watch out for this seller though...he sells good stuff but has a tendency to misrepresent parts as being much better that what you actually get (wife actually runs the show there so that shld explain a lot). Good luck................................Mike
Vroom-vroom!!!
(2)-1976 KZ900B-LTD's
1-all stock low mileage...
1 modified
1977 KZ1000 (awaiting resurrection!) :)
...and an old school Honda CB750 Chopper is next on my bucket list!
Oh...and a Pocket Rocket lol!!!
Last edit: 23 Jan 2016 23:09 by Rockranch. Reason: msp
  • peter1958
  • peter1958's Avatar
24 Jan 2016 01:15
#707839
you realy need to say what bike your working on first.If its a j model engine its 44 th pin on chain. Lots of slack in chain because of cam cover not installed. You need to look for proper instructions. This site does have a search.
  • peter1958
  • huntersdad14
24 Jan 2016 03:18
#707841
Sorry Peter thought the year 1995 gave it away lol. It's a 1995 kz1000p.
Jeremy
  • Old Man Rock
  • Old Man Rock's Avatar
24 Jan 2016 03:55
#707843
Hey Jeremy.... Ah so I see ya keepin the old girl.... B)
New Battery, Starter then do the compression check we spoke of.....
If fairly good, I'll bring the set of 28's over just to see if she'll fire to life.....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
