KZ1000 1977 goose Bike build
- COKID
Re: KZ1000 1977 goose Bike build
09 Nov 2015 16:40
Doing good on the build. Got my alloy wheels. Rear wheel hub didn't match from the spoke hub. Ordered hub that should fit. Got the swing arm off finally. Removed handlebars and cabling that was through the bars.
Have to remove the forks next. Need lots of parts. Concentrating on getting all hardware off for plating and sent off. I think I'll start from the front and work my way back.
Didn't know that the goose bike wasn't well known. The real goose bike was. a 77 KZ1000. I'll do the best I can .
Regards,
COKID
ydacco
Regards,
COKID
ydacco
70 XS1
77 XLCR
77 KZ 1000
2000 Z10
2013 KLR 650
2015 XG 750
77 XLCR
77 KZ 1000
2000 Z10
2013 KLR 650
2015 XG 750
- Daeldren
09 Nov 2015 18:55
Screw the Bronze, we all know that Bubba Zanetti and Toecutter's bikes were the best.
I'll be watching your progress, good luck.
Is something burning?
1984 GPz 750
1994 Xl 883
1984 GPz 750
1994 Xl 883
- COKID
10 Nov 2015 04:08
70 XS1
77 XLCR
77 KZ 1000
2000 Z10
2013 KLR 650
2015 XG 750
77 XLCR
77 KZ 1000
2000 Z10
2013 KLR 650
2015 XG 750
10 Nov 2015 04:31
I thought so. I wonder how much flow would make it to the cooler that way. I'm trying to get these but they're out of stock.
10 Nov 2015 04:47
No eBay APP ID and/or Cert ID defined in Kunena configurationBeen relisted. He makes lots of other goodies.
- Rockranch
10 Nov 2015 04:47 - 10 Nov 2015 04:49
Good question, as I am curious as to the same thing for my KZ 1327 build. I suppose if anyone had that info (calculations) it wld be Patton. He seems to have a collection of genuine printed material and information and someone once compared his collection of info to the Library of Congress.
(2)-1976 KZ900B-LTD's
1-all stock low mileage...
1 modified
1977 KZ1000 (awaiting resurrection!)
...and an old school Honda CB750 Chopper is next on my bucket list!
Oh...and a Pocket Rocket lol!!!
1 modified
Last edit: 10 Nov 2015 04:49 by Rockranch. Reason: unf
10 Nov 2015 04:55
I guess if even 1/4 of the flow made it to the cooler it would help if in more cooling surface.
- Rockranch
10 Nov 2015 05:04
My thought is to temporarily connect it with a clear line to get a visual of the flow rate.
1 modified
1 modified
10 Nov 2015 05:16
Good idea. I'm thinking about some kind of bypass valve for winter riding.
- Rockranch
10 Nov 2015 06:02
I've used that method in the past on 2-cyl and 3-cyl bikes and got good visuals of actual oil system flow rates at various rpm's with good success. I'm sure it wld work the same on any motor.
swest wrote: Good idea. I'm thinking about some kind of bypass valve for winter riding.
1 modified
1 modified
- SmokyOwl
10 Nov 2015 08:00
Subbed to this thread- knew exactly what was goin' on when I read the title
I wish you an easy-going build sir and best of luck with it. Fans rejoice around these things.
1982 Kawasaki KZ1100 A2, Shaft
Never trade the thrill of living for the safety of existance.
- COKID
07 Dec 2015 20:09
Quick update. Replaced fork seals and cleaned and lubed fork stem bearings. Need to add 10 weight fork oil. Rebuilt front and rear master cylinders. Rebuilt front caliper. Need new seals to complete rear caliper rebuild. Replaced front pitted piston. Replaced one rear caliper piston. Replaced turn signal lamps and reused stems. Rewired turn signals.
Bought cast wheels, and 4-2 exhaust. Bought used seat to use during shakedown. Cleaned petcock, but need new seals.
Still waiting on my hardware to be returned from plating.
Funds are low due to new bathroom costs and Christmas etc etc. eventually I'll get new tires mounted and all the misc rubber bits seals and hoses cabling etc. doing all labor like polishing and painting. Rust removal and the like. Also need new handle bars. It's cleaning up nicely.
Regards,
COKID
Regards,
COKID
70 XS1
77 XLCR
77 KZ 1000
2000 Z10
2013 KLR 650
2015 XG 750
77 XLCR
77 KZ 1000
2000 Z10
2013 KLR 650
2015 XG 750
