1981 gpz1100 project resto-mod
  • missionkz
  • missionkz's Avatar
Re: 1981 gpz1100 project resto-mod - update pics
04 Sep 2015 14:48
#688668
I brought the tank in my avatar to a local auto body and asked them how much to shoot clear coat on it and I would do the prep, the final 1500-2000 wet sand and polish.... they said $200.00 I said F**K you... I did all my self with rattle cans.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • mjg15
  • mjg15's Avatar
04 Sep 2015 21:32
#688702
missionkz wrote: I brought the tank in my avatar to a local auto body and asked them how much to shoot clear coat on it and I would do the prep, the final 1500-2000 wet sand and polish.... they said $200.00 I said F**K you... I did all my self with rattle cans.
Dont spill fuel on it.... Does look nice.
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
  • 577nitro
  • 577nitro's Avatar Topic Author
05 Sep 2015 11:07
#688764
Eastmans makes a two part fuel proof clear coat that works fantastic. Just google it.
The following user(s) said Thank You: Greybeard
  • mjg15
  • mjg15's Avatar
07 Sep 2015 14:20
#689043
Cool, sounds handy, I'll take a look
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
  • 577nitro
Re: Re:1981 gpz1100 project resto-mod
21 Sep 2015 17:39
#691261
Hey sent you a pm on your gxsr600 swing arm measurements.
  • 577nitro
27 Dec 2015 18:29
#704592
Just an update, I have been working pretty hard on the 550, trying to get it done for spring, I'm down to painting the wheels and having the frame blasted and painted. I was going to have it powder coated, however due to the cost, I decided to just paint it myself. Thats the way it came from the factory so its good enough for me. And the paint i use is epoxy based and tougher than crap.
  • 577nitro
27 Dec 2016 01:30
#750755
Hi all...just an update. 550 is waiting for the frame to be blasted still; all other parts done. I am debating on a big bore kit and a megacycle cam with a road race grind. It would wake it up nicely. The 1100 is mostly done, rear end is mounted with a modified stock swingarm and the 87 gxsr 18" rear wheel. I purchased a 87 gixxer rear brake and rebuilt and mounted it. Had to weld a bracket on the bottom of the swing arm for the torque arm. Mounted up the zephyr shocks, no prob. Front wheel FINALLY fitted with the 86 gsxr 18" wheel, had to mill the mounting points for the rotors almost 10"mm. Fabricated adapters for the brakes and milled spacers and shims for the 15 mm to 17 mm bearing and axle. And it all works....18" gsxr wheels on a GPZ1100. Really makes it look like S1 with those wheels. I bought a zrx 1100 swing arm, but..it does not bolt up, slightly to wide between pivot holes. Also the lower bar of the arm does not clear the Kerker pipe. So I guessing this needs to be modified (the kerker?) The tank still needs to be sorted, I really want a late model J tank, I have two GPZ1100 tanks I could trade for one? I was also thinking about dropping in a megecycle .385" cam to beef it up a bit.
  • 577nitro
25 Aug 2017 23:14
#769773
Here is the latest update. Finally finished up mounting the ZN700 instruments...I'm really happy with the out come. Looks factory and bolted pretty much right up. A little trimming here and there but not much. Wiring was one to one...can't get any easier than that.
GSXR 18" Wheels, front and rear fully mounted and functional, chain converted to 530, 34 mm flat sides mounted, Brakes mounted and functional. Last and biggest pain, gpz fuel tank petcock interfering with the carbs. Only thing I can think of is cutting the old mount point and welding it further back. i can't do that, my welding skills are not that good.
But almost there! In the mean time I bought a sweet 2000 ZRX1100. I'll have one old and one newish...
  • 577nitro
30 Aug 2017 22:52
#770042
YES! Finally have the GPZ1100 on the road! It looks awesome exactly what I was going for..and pioneered new ways to update these.
Adapting the 87 GSXR wheels, I think , is best way to get that original S1 look without having to spend $5000.00 on dynomags. And they are friggin cool looking. 310 mm full floating disk, modern tires, fully adjustable KYB ZRX rear shock, upgraded meters...and those gorgeous RS flat slides; which are driving me nuts at the moment tuning. When she gets on the pipe it goes like stink.
As far as I know this is the first and only conversion to 18" gixxer wheels.
  • 577nitro
09 Jul 2019 09:57
#807254
Some Photos of the 81 GPZ1100, these are without the new set of S1 style rear sets.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
09 Jul 2019 10:08
#807255
Beautiful.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • scubaanders
  • scubaanders's Avatar
09 Jul 2019 10:18
#807256
Congrats to a beautiful build :woohoo:
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
The following user(s) said Thank You: 577nitro
