- Thank you received: 2829
Kiwi KZP
larriken wrote: Also managed to get five mins in today and pop the top off the motor. Bummer, two bolts shared straight off. At least I know what I will be doing tomorrow.
You really need to buy a can of Kroil. Soaking stuck fasteners for a couple days and then removing them with no trouble is FAR easier than trying to remove broken fasteners. The stuff really does work; I have used it on quite a few stubborn fasteners and never had a problem removing them after a good soak. No kidding! See link below, and below that is the picture of the product I use. It works! Ed
www.kanolabs.com/penLub.html
Attachment Kroil_2014-12-17.jpg not found
- larriken
- Thank you received: 61
cc to under 1000. Also in that same secret pile of bits I also have a set of cams from an 84 GPZ1100. Fingers crossed it should be a good mix and give it a little bit more up and go without busting the bank.
- larriken
My box in the corner of the workshop, been collecting bits for zeds for a time and it's great to finally be able to use what's in the box! What is awesome about the Police Kz is it's really really easy to get bits for them.
Another peek in the stash pile.......................................
- Thank you received: 797
you may slide a feeler gauge between the rod and crank to check the big end side clearance.
these old lower ends are pretty solid.
no weird discoloring on the rods????
prolly fine,a hone and them new bits you'll be doing long smokey burnouts in no time :evil: .
- Thank you received: 2744
- larriken
- larriken
- larriken
- larriken
- larriken
