OMR's new girl: '76 KZ-900-A4 Barn find
  • KZPETE33
  • KZPETE33's Avatar
  • 76 900 Constant thorn in my side....love it.
Re: OMR's new girl: '76 KZ-900-A4 Barn find
26 Apr 2015 11:35
#669640
Wanna sell that Kerker ?
  • mike1957
  • mike1957's Avatar
26 Apr 2015 19:07
#669695
Nice ,good luck with it . Still working on my 76 900
7 yrs now- don't plan on selling it.
mike1957
  • loudhvx
  • loudhvx's Avatar
26 Apr 2015 19:56
#669703
Wow, very clean looking bike. Very Nize. B)
  • kaw-a-holic
  • kaw-a-holic's Avatar
26 Apr 2015 20:40
#669706
Nice OMR, can't wait to pick up my 74 Z1 this summer, has the stock 4 into 2 in perfect condition. Unfortunately, no air box. I don't know if I should restore it of flip it.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • Old Man Rock
  • Old Man Rock's Avatar Topic Author
27 Apr 2015 04:41 - 27 Apr 2015 04:47
#669724
@ Kaw-a.... Being a '74 Z1..... No brainer, Restore and keep her for awhile.
A clean build these days is fetching $10k plus.... Can only imagine what she'll fetch in 10 years. :ohmy:
BTW... I have the '78 KZ-1000 air box, not sure if the same on the KZ900 but would think they are.... You can have if you want it.... PM a phone number if interested.
OK, these carbs are toast.... Been soaking in penetrating oil for 2 days now and slides are still stuck in closed position.
So need to find a good set of 26mm's for this KZ. I alreayd have a set of 26mm from a '78 KZ 1000 (pilots on bottom) but doesn't match the 26mm for the '76 KZ900 (pilots on top).
So e-mail sent to Brian otherwise off to e-bay I go.... :whistle: :laugh:
Thanks for the replys all....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 27 Apr 2015 04:47 by Old Man Rock.
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
27 Apr 2015 05:08
#669725
You brought me back Rock when I saw this beaut . Super nice find.
  • SWest
  • SWest's Avatar
  • 10 22 2014
27 Apr 2015 05:54
#669728
Try carb and choke cleaner. Spray in the top and the bottom. There's a clear coating that might come off but new slides are available at jetsrus.
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
27 Apr 2015 07:08
#669734
Old Man Rock wrote: OK, these carbs are toast.... Been soaking in penetrating oil for 2 days now and slides are still stuck in closed position.
OMR
OMR, why not give it one more shot and boil it in a diluted bath of lemon juice. I purchased a big pot from the good will and cooked them outside on the bbq side burner. Don't have to worry about diaphragms. Nothing to lose.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
27 Apr 2015 07:18
#669736
killer score omr!
i agree that a boiling hot bath might help free the slides.
as you know heat expands,
  • dom2570
  • dom2570's Avatar
Re: Re:OMR's new girl: '76 KZ-900-A4 Barn find
27 Apr 2015 12:45
#669779
That seat is epic!
Whip it like a mule!
  • missionkz
  • missionkz's Avatar
27 Apr 2015 13:13
#669782
Don't buy any used carbs yet.
Remove the caps off the top of the carbs and pour boiling water and lemon juice mix in the top of the carb where the the arms are.
Do it over a tub so you can drop them in it and let it soak,
Then if still stuck, go get a gallon of generic acetone and automatic transmission fluid.
Mix it about 3 parts acetone to one part tranny fluid.
Actually maybe just do this in the first place!
Soak the bodies in that for a while and they will come loose, especially if you pull the throttle and choke control shafts all the way out and remove the carb bodies from the carb mounting assembly plate.
I've never had a carb that I could not get the slide loose on and I've had some real GRONKS that lived outside, along side garages and in fields for years!!
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
28 Apr 2015 08:13
#669856
Nice pick up!
Soak the carbs in 100% undiluted Pine Sol.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
