1981 J model Endurance racer
  • timmythecop
  • timmythecop's Avatar Topic Author
Re: 1981 J model Endurance racer
13 Jul 2015 15:02
#680730
Footrests. Left metal on right side in case i need exhaust mount but mist if not all will be cut away. Secong pic shows where a bung on each side needs to go. Third is the chopped fairing. Not 100 % on it, but it is a gauges and headlight problem solver
Can I convince you to paint it flat black?
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
14 Jul 2015 06:02
#680784
brutal :evil:
  • larriken
  • larriken's Avatar
15 Jul 2015 01:20
#680934
Sweet, like the chopped peg hangers. Was thinking about doing that to one of my bikes.
  • timmythecop
18 Jul 2015 20:11 - 18 Jul 2015 20:13
#681571
Attachment aaaaaaaaaaaa.jpg not found
well.....the seat will not do. Too cafe boy street racer and too round. The fairing shown will also not be used for the same 2 reasons. now I am leaning towards no fairing but 2 large frame mounted headlights. we shall see.
I did get KZ stem into the Vf750 triple today, although I did it the taboo way. If I had pressed out the VF stem, the hole left would have been too big for the KZ stem, so, I cut the VF stem off flush and then necked the KZ stem down to fit inside the leftover part of the VF stem. Then i machined all 3 surfaces down to nice and tidy and ran a bead of weld in a circle. I know you are not supposed to do this, but the KZ stem is really beefy and I only removed .5 mm or so. worked nicely and I am happy. now onto the back. Gotta make a new spacer but no big deal, BUT....can anyone tell me at what angle the swingarm can go to before it becomes a problem with chain run (up and down) ? I want to move the mounts forward, but I am afraid of sawing my fabu arm in half with the chain.
here she sits
Last edit: 18 Jul 2015 20:13 by timmythecop.
  • timmythecop
25 Jul 2015 11:26
#682682
sorta decided on this seat.
  • timmythecop
25 Jul 2015 11:28 - 25 Jul 2015 11:28
#682683
splitting tomorrow to go ride the Eifel Forrest in Germany. I'll be on the lookout for any cool Kawalskis I can find. Cant wait to do this again:
Last edit: 25 Jul 2015 11:28 by timmythecop.
  • timmythecop
04 Aug 2015 07:09 - 04 Aug 2015 07:12
#684221
not a KZ, but plenty of time on a KAWASAKI
Attachment 11822312_10207316862659552_43634012511087656_n.jpg not found
Last edit: 04 Aug 2015 07:12 by timmythecop.
  • timmythecop
16 Sep 2015 14:11 - 16 Sep 2015 14:14
#690367
Attachment aasbb.jpg not found
Attachment aasaa.jpg not found
progress is so slow. Only new stuff is the fact that I decided to use an internal baffle inside the link pipe and run no can at all. (I hope I can jet around this) Also decided on a frame mount dual headlight set up and no fairing. Still stymied on the seat...........
Last edit: 16 Sep 2015 14:14 by timmythecop.
  • timmythecop
16 Sep 2015 14:19
#690369
oh, one more thing.. the footrest hangers are getting closer to final shape
Attachment aaassccc.jpg not found
  • 531blackbanshee
  • Vendor
  • Vendor
17 Sep 2015 03:33
#690437
i wanna ride it!!! :evil:
  • timmythecop
17 Sep 2015 13:26 - 17 Sep 2015 13:28
#690546
Just finalizing the measurements to take metal off sprocket carrier and make suitable spacers. No big hurdles there. Havent decided to use VF750 or KZ rear brake, prolly use the one that gives me the least amount of jib. other than that I need head bearings and wiring, and it should be a complete roller. The jetting was 95% there with a horrible can, so I am at worse, close.
Still not sure about seat. Has anyone ever used one of these on a later KZ frame. (its close, but not completely optimal)
Attachment aaabbbccc.jpg not found
Attachment aaabbbcccddd.jpg not found
Last edit: 17 Sep 2015 13:28 by timmythecop.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
18 Sep 2015 10:28
#690702
Isn't that a Honda style tail?
You need something like the H2R2 seat that fits the KZ frame:
www.airtech-streamlining.com/kawiz/Z11973-80.htm
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
