- Thank you received: 249
Phoenix Fighter
- kaw-a-holic
I get that Leon, I may get it done and not like how it feels. Know way to know until I try it.531blackbanshee wrote: i've been vocal about not being a fan of hyd.clutches in the past.it's down to the lack of feel for me,personal preference.
but as a machinist and fabricator i get into some stuff i wouldn't normally do for myself :whistle: .
i currently have one such case of modding a pmfr outboard support to use a
i had to slot the mounting holes on the slave and bore the hole open to match the slave body but it was a straightforward deal.
here you can see the slotting that had to happen.
thanks to Kawboy74 for his information sharing.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- kaw-a-holic
swest wrote: I remember, gotta cost a bundle though. How's it running anyway?
Running good now. The bolt did not back out like I thought it did. I tightened the bolt so much that the disc ended up digging into the unit near the optical receiver. It shaved of a tiny bit of plastic and ended up covering up the optical reclever causing the ignition to stop working. I put a spacer in it and it's all good now. Over all I am happy with the bike. There will be a few tweets here and there but I am happy with it. I am really disappointed in the POR 15 engine paint, it is already changing color.
Jon
1977 KZ1000a1
Mesa, AZ
- Thank you received: 2740
- kaw-a-holic
swest wrote: Glad to hear it. The tank is changing color?
No the engine paint is changing color on the head.
Jon
1977 KZ1000a1
Mesa, AZ
- Thank you received: 797
i'd be surprised to find any coating that didn't discolor around the exhaust.
- kaw-a-holic
531blackbanshee wrote: these heads get really hot on the exhaust side.
Well damn, I may have to just blast the paint off of it and leave it bare aluminum.
Jon
1977 KZ1000a1
Mesa, AZ
Styeve
- kaw-a-holic
swest wrote: Or mask and spray it black. :dry:
Styeve
No, that is part of the problem also is it did not prepare it correctly so the paint is chipping. It should have been sand blasted but I did not want to split the cases at the time as I thought I was still going to make the Flag Rally in CO. I soda blasted it as I knew the soda is water soluble and wouldn't have to worry if some managed to get inside the cases.
Jon
1977 KZ1000a1
Mesa, AZ
- kaw-a-holic
Jon
1977 KZ1000a1
Mesa, AZ
- Kawboy74
- Thank you received: 52
David
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
- Kawboy74
