- Thank you received: 249
Phoenix Fighter
- kaw-a-holic
swest wrote: I assumed you did because you're not a cheap Ba**ard. :lol:
I hesitated because the bike only had 25K on it and I did not want to splint the cases and was not sure about using a split chain. I didn't have any issues like this prior to the rebuild.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- kaw-a-holic
les holt wrote: I thought a sight like this from my past would have been evidence enough to convince any guy to put a new chain in!
Attachment broketimingchain.jpg not found
Les
Ouch! Thanks for the motivation Les.
Jon
1977 KZ1000a1
Mesa, AZ
- les holt
- Thank you received: 288
Les
- Thank you received: 2740
- kaw-a-holic
I drained the oil and will be inspecting the clutch basket this morning. What am I supposed to keep the clutch from slipping?
Jon
1977 KZ1000a1
Mesa, AZ
- Thank you received: 2061
swest wrote: Being it's been sitting, it might just be some of the plates are stuck together. As suggested you might want to smooth out rough spots on the inner aluminum part of the basket. I have two extra if you need one. Check the spring length and if they sit square too. I have stock ones and never had any problems with them. Being you're going hydrolik I guess APE ones won't be a issue.
IF any clutch plates were STUCK together the clutch would NOT RELEASE.
Jon has a problem with the clutch SLIPPING not fused together and locked up.
Jon, Try readjusting the clutch first before tearing it down.
Then if that is not a adjustment issue tear it down and inspect all components.
Take some pics at that time and we will find a solution for you
- les holt
Les
- kaw-a-holic
Jon
1977 KZ1000a1
Mesa, AZ
- kaw-a-holic
kaw-a-holic wrote: The springs are brand new, as well as the friction discs. The springs are EBC and 10% heavier than stock. The friction discs, I must have been tight on money at the time as they are not name brand. Once I get the hydraulic clutch working correctly I will upgrade to APE. I am going to pull it all apart, clean everything up and put Lucas 20-50 wet clutch oil in her and take her for another ride. fingers crossed.
Agreed Les. I have it mounted where the Slave cylinder is % collapsed and there is just enough pressure to on the push rod to keep it taught.
Jon
1977 KZ1000a1
Mesa, AZ
- les holt
Les
