- Thank you received: 249
Phoenix Fighter
- kaw-a-holic
I am using a GSXR 1000 slave cylinder. I opted for it solely due to the fact that it uses 2 bolts and was easier to layout using one center line. The MC was not a 14mm, packing said it was but upon closer inspection, it is stamped 5/8". I will just order one from Shindy and be done with it. The 5/8 MC did move the piston, just not enough. My slave cylinder has a recess with a divet just the right size to cradle my push rod. I spaced my plate so the the slave cylinder is completely collapsed and has solid pressure on the push rod.davido wrote: Im also sure it will work. What Im wondering about is the spacing twixt the engine block and the mounting plate.
For instance,On my ZXR slave cylinder,I have the cylinder,then a large spring,then the piston,with a ball bearing in the center. This will butt up against the dimple in the end of the clutch push rod.
When the plate is mounted with the slave cylinder in place,and everything is 'at rest' should the piston be fully retracted ,fully compressing the spring ?
How did you space yours?
(My brain is turning over now. Maybe this is somethig to do with why yours didnt work out! Maybe you did get a 14mm bore master cylinder but the spacing of the slave wasnt right??)
Im sure I can sort it when its all together but I would like to set it up dry first as close as I can.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- davido
- Thank you received: 292
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- Rockranch
- Thank you received: 23
Vroom-vroom!!!
(2)-1976 KZ900B-LTD's
1-all stock low mileage...
1 modified
1977 KZ1000 (awaiting resurrection!)
...and an old school Honda CB750 Chopper is next on my bucket list!
Oh...and a Pocket Rocket lol!!!
- kaw-a-holic
davido wrote: On another point Jon,did you get youhydraulic cluth working in the end? Im busy with mine again and am wondering if I can get the spacing sorted out 'Dry' without filling the system.Any advice?
I must have missed this David. I would definitely do the spacing with the system dry. If you try to bleed the system without it mounted it will just spit the plunger out and you will have a real mess on your hands.
Jon
1977 KZ1000a1
Mesa, AZ
- kaw-a-holic
So it was running great, idle through WOT. I turned left started rolling on the throttle hard then cough, cough sputter......dead. Time is out and it won't start, turns over fine but spit a flame out the tail pipe. I just went through everything on the top end last night. I found that the camshafts were out of time again last night. I don't know why the timing would keep jumping. I'm using the stock auto timing chain adjuster. The only thing I can think of is a stretched timing chain. I tried to check it for service limits but what the FSM says and that the actual measurement is, is short thanotice the service limit is. If someone could post what it is supposed to be at "X" number of links I would appreciate it greatly.
Jon
1977 KZ1000a1
Mesa, AZ
- Thank you received: 2763
- kaw-a-holic
I don't have an issue with buying an APE manual adjuster if it fixes the issue. I have a DID chain with a peen master link I could put in.swest wrote: The stock auto timing adjusters had problems. You can make yours manual. I ran my timing chain through two rebuilds. This time around I put in a new one. Side by side the old one sagged 1/4". Not enough to worry about.
Jon
1977 KZ1000a1
Mesa, AZ
- pete greek1
- Thank you received: 185
Pete
- kaw-a-holic
pete greek1 wrote: Did you replace your cam chain rollers when you replaced the chain ?
Pete
I didn't replace the chain but replacedon't everything else
Jon
1977 KZ1000a1
Mesa, AZ
- les holt
- Thank you received: 288
Attachment broketimingchain.jpg not found
Les
